Cylinder Head Bolts will not loosen
They loosened about a quarter of a turn for the ones that I tried but not all the way...
How do I get those damn things out?
What do I do if I can't get them loose? Is there someone I could call out of the phone book or a tool that I could buy...
You can spray them with a penetrating oil and let them sit for a bit..
Heat sometimes helps also..
Then as Ps2cho posted, use the longest breaker bar you can get..
If still no movement, you can get more mechanical advantage by sliding a two to three foot length of pipe over the handle of the breaker bar.
Don't use too long of an extension on the socket as you want to keep everything square.
You can bang the breaker bar with a hammer to "shock" the bolt loose...
Remember upon reinstall there is a VERY SPECIFIC tightening sequence. Look at the FSM if you have not in regards to this. It is very important. Head bolts must be replaced FYI...they should not be reused.
It said in the FSM to NOT spray or put any oils on the bolts because it might damage the crankcase.
I'll keep all that in mind if all else fails...
No mention of not using penetrating oil.
Don't know what chemically can even begin to cause crankcase damage.
Almost impossible for any amount sprayed at the base of the head to migrate to the crankcase.
Penetrating oil is standard operating procedure to remove any "frozen" bolt or nut.
Simple instructions:
"21. Slacken cylinder head bolts when engine cold in the reverse order to the tightening diagram, starting with 14."
May be difficult to break a center bolt loose versus the end bolt as the overall torque on the head acts like a belleville washer against the bolt head.
Again as Ps2cho stated, install all new cylinder head bolts as the existing may have a bit of stretch.
Good Luck.
Ed A.
So Im guessing those 3-4 screws on the inside top side of the intake manifold to the cylinder head is whats keeping it attached now?
How do I clean the threads on the engine block? Im getting the cylinder head check etc. It says not to spray anything into the threads of the block is what I was trying to say on the other post.
Anyone know where I can find that brush locally that Samstag offers online?
Man the UK thread is gone that ***** is toast. Someone took it off or Im not looking in the right place. What's the thread for it again? It explains what Im looking for...
Main reason they don't want you to spray anything on the threads is because it gives an inaccurate reading when you torque the new bolts down.
Find a small bottle brush which will work...
I understand the 13mm bolts that fasten the intake manifold to the head. Im going to get new wrenches tomorrow to do that. They look like a pain in the ***.
The 6mm screw holding the trans dipstick is not threading correctly and its not turning. Couldn't get it out today. Its all the way up against the firewall. WTF!...
Also is there such thing as taking out the head with the cam in one piece removed from the sprocket?
I zip tied the sprocket and timing chain together so I don't have to worry about setting it up again. Im trying to slip out the cam and head all in one piece...
Do those 5 bolts have to come out completely or can they sit in there a little bit because it looks like they would be difficult to thread back in?
I got the first support strut bolt out for the Intake Manifold but, can't get the other one...It's really up in there.
Is it even terribly neccessary for me to get that other bolt out?
Here's a pic of that 6mm Trans Dipstick mount screw...Like I said before the thread is gone im going to try a pocket knife next.
Got any ideas for that and the other intake manifold strut bolt?
I tried to put a pic of it up but its not working right now...
