W124 Overhauled Tranny with no 4th gear ! help please
You may notice from the title that i am fully desparate !
My 190E tranny wont shift to 4th gear even with a new overhaul kit "installed", there are no problems in the fluid & the filter.
my friend told me that it might be the servo valve of the k2 clutch which works on the 4th gear ?? so whats your ideas ?
I can't pass 35mph because the engine will keeep shouting
which i don't want to hear ....thanks
will the modulator cause this problem ?
( I am just asking ... because I don't know
Let me see if I can dig up the specs for each transmission # It is worth a shot because it should be set to spec either way regardless.
Also have you made sure your control pressure cable (attached to throttle) is set right? Since you removed the transmission it must have been taken off so make sure it is right. If it is not right the car will just keep going up in RPM (as you mentioned) because the shift is heavily delayed.
Follow this here:
http://www.ps2cho.net/downloads/MB%2...adjustment.pdf
I know yours is the 4cyl, but the principle should be the same I would guess?
If you have a large vacuum leak or it is highly out of spec I would guess it is possible.
but if i choose (2) with a very slow speed (near to zero) it will pick 1st by itself .. then i shift to (d) so it will shift normally !
and thanks for your fast responses .. i apretiate that
because it is currently shifts normally between 2-3 ,
you mentioned the modulator... can you please tell me more about it ? because i cant understand its functionality very well .. and again forgive me
what things still not checked ?
again could be the modulator (because i don't know why it is used- the car has a pressure control cable connected to it so why it uses the vacuum system)?
thanks
