Please Help my 300CE overheating
I have all these parts that I put are Brand New
Radiator-Brand New
Water Pump-Brand New
Clutch-Brand New
Fan Blade-Brand New
Hoses-Brand New
Thermostat-Brand New(Have Tried using the 79C and 87C and still no luck)
DOES ANYONE KNOW THE ANSWER? ITS DRIVING ME CRAZY BECAUSE SOON ENOUGH IM GOING TO OVERHEAT MY ENGINE
If all cooling systems components are working properly and it still overheats...you may have a blown head gasket.
oh crap, I think my head gasket is leaking
Woke up in the morning, there's a puddle of oil underneath my car.
I cant believe it, the car has only 46k miles
thanks so much for your help
after having replaced with a brand new radiator, water pump etc, i would suggest checking the car's fan coupling....this is done by trying to spin the fan...
if it is very easy to spin the fan...the fan's coupling needs to be replace......because normally there should be some resistance....
your mechanic should have check this coupling when replacing the radiator etc...
You can always just run the heat full blast to avoid a overheating situation in a pinch.
-Mike
If you mean that then the clutch fan is brand new
-Mike
Good luck!
