Final pics of my drop and Monoblocks
Old May 7, 2010 | 04:39 PM
edcarls's Avatar
97R129-01W163-94E320-93500E
Originally Posted by ps2cho
I did not. We'll see how long the tires last and go from there. According to my alignment specs, I am -2deg camber rear and 1.8 front. Is that a lot? I am not quite familiar with what would be considered "wear zone" neg camber...
I think you are within spec. IIRC -3 is the max you can go to avoid uneven tire wear. The reason I ask is that I noticed in the pictures your tires are so perpendicular and appears to have no negative cambers at all. Good job!
Old May 11, 2010 | 02:37 AM
BJaltima's Avatar
1993 400E, 1994 E420, 2000 SL500, 2014 C250
I love those rims so much more than the last ones (sorry)
And 245 tires would really help that gap. I did that with my 19's on my old car when I wanted to close the gap, but not lower it anymore.
How would that black grille look on a white benz, in your opinion?
Old May 17, 2010 | 12:13 AM
ps2cho's Avatar
E
Anyone know a site that sells the spring pads anywhere?
Managed to find the part #'s on a thread over at peachparts
Originally Posted by gsxr
The struts and shocks are gas pressurized, so if your old ones were really shot (zero pressure), it's possible that new ones may have raised the ride height slightly. It may settle down over a few weeks or months. Anyway, about the pads/shims, try searching directly by part number:
Spring pads / shims
201-321-09-44 - Front, 1-point (8mm)
201-321-10-44 - Front, 2-point (13mm)
201-321-11-44 - Front, 3-point (18mm)
201-321-12-44 - Front, 4-point (23mm)
201-325-09-44 - Rear, 1-point (8mm)
201-325-10-44 - Rear, 2-point (13mm)
201-325-11-44 - Rear, 3-point (18mm)
Also, I noticed on big dips in the road my front bumper was touching. I hear there is a "travel limiter":
But I've seen them sell for $150 !!??? There must be another way I can limit my travel similar to this...
Old May 17, 2010 | 01:13 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Wow, no idea they were that much. Those do sound interesting though. Really tighten up the suspension.
Old May 17, 2010 | 02:00 AM
ps2cho's Avatar
E
Well not really since when do you turn so hard your shocks are depressed that much? I see it only benefiting tightness when you are so low you are actually riding on the bump stops themselves. I want it only for its name purpose -- travel limiter.
Old May 17, 2010 | 12:38 PM
edcarls's Avatar
Travel limiter for $150...save your money for something else. I used two 20mm caster wheels I bought from Home Depot. I removed it from its mount and bored out the center hole to fit the strut's shaft. No more scraping due to bottoming out.
Old May 17, 2010 | 03:59 PM
  #32
YNVDIZW124's Avatar
lots of cars
I can have them made if you want....
Old May 17, 2010 | 04:41 PM
  #33
ps2cho's Avatar
E
I just had a local shop look for the #1 spring pads using the part # 201 321 09 44 and it returned nothing...
A little more research and found this thread:
https://mbworld.org/forums/e-class-w...t-numbers.html
FRONT
210 321 01 84 - #1
210 321 02 84 - #2
210 321 03 84 - #3
210 321 04 84 - #4
210 321 05 84 - #5
REAR
210 325 01 84 - #1
210 325 02 84 - #2
210 325 03 84 - #3
210 325 04 84 - #4
Looks like that part # was recognized....So the 210's will work ok on the 124 chassis?
Ynv I'll pm you later!
Old May 18, 2010 | 10:41 AM
  #34
edcarls's Avatar
I got some spring pads from Walters for I think less than $10. They don't have it in stock. So you have to pre-pay, they'll order it and you can pick it up in a day or two.
Old May 18, 2010 | 12:29 PM
  #35
pifcat2's Avatar
300TE / 300E / 300CE
I thought I sent you this site before: http://www.allpartsexpress.com/ShopB...sorber&mode=PA
Old May 18, 2010 | 03:39 PM
  #36
ps2cho's Avatar
E
No...but thanks!
Unfortunately they only have (1) available Dang it!! I'll shoot them an email...
Any chance you know what the part# is?
If I order from allpartsexpress/peachparts the shipping ends up more than the price of the dealership most times. The guy at my local stealership, I think, gives me the business discounts as the final price is always a LOT less than the list price. ie: idle air hose list price $26 I got it for $13. OE motor mount list $153 I got it for $98
Old May 18, 2010 | 05:38 PM
  #37
edcarls's Avatar
No...but thanks!
I think I used the plastic wrap to store my old pads. I'll look for it and post the # here tomorrow.
Old May 18, 2010 | 08:48 PM
  #38
YNVDIZW124's Avatar
lots of cars
w202/w210 pads also work on w124s.....I should have said that earlier...You can get them on ebay pretty cheap...
Old May 19, 2010 | 11:34 AM
  #39
edcarls's Avatar
The front 8mm shim part no. is 210 321 09 84
Old May 19, 2010 | 09:40 PM
  #40
shenagles's Avatar
1990 300e24
I have those travel limiters (from previous owner) works good, still wouldnt pay 150 though thats crazy. Maybe get them made. How about a stiffer shock/shorter. Like a bilstein sport or something, or just remember your car is lower and go really slow over....everything haha
Old May 26, 2010 | 11:54 PM
  #41
ps2cho's Avatar
E
Got my #1 spring pads on.
Here's the difference between a #3 and #1
I didn't know this, but it seems there are little 'tabs' as you can see that denote what # spring pad you have.
Old May 26, 2010 | 11:56 PM
  #42
1990 300ce 24v I6
All well and good. Tell me what you're building with that nice heatsink :P
You have Steam?
Old May 27, 2010 | 12:00 AM
  #43
ps2cho's Avatar
E
*off topic!*
Replacing my Ultra 120 extreme with it as I got a badly concave one and battled temperatures on my Q6600. Since I have it clocked at 3.6GHz 1.5v she enjoyed putting out 74/75c full load when with that heatsink seeing it is one of the best, I should have been around 68'ish. Got this Corsair H05 with some bestbuy rewards coupons from a prior laptop purchase for like $30.
Yep I got steam. Username same as here.
Old May 27, 2010 | 12:25 AM
  #44
1990 300ce 24v I6
Still
I just built my "Green" gaming rig earlier this year. C2d e7600 @ 3.06ghz, 8gb DDR3 1066, 32gb PS-100 SSD, 500gb WD 5000AADS, Palit GT240 1gb DDR5 OC. I also put some nice green LED fans in it, a LCD control panel, and I went a little nuts and wired in some green EL wire along the outside air grates.
I added you on Steam BTW.
Love this thing Stays cool, pulls only a few watts, and tears through most everything I game on it as well as my work. Huge step up from my ancient P4 3.06ghz with 2gb DDR2100 and 7600GT AGP on 4x AGP bus.
Back to our regularly scheduled programming.
Old May 27, 2010 | 01:02 AM
  #45
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Nerd Alert!
Old May 27, 2010 | 01:07 AM
  #46
1990 300ce 24v I6
Oh hush. Nothing wrong with making everything in your life go fast :P People like you pay people like me lots of money
Old May 27, 2010 | 03:03 AM
  #47
ps2cho's Avatar
E
Originally Posted by rivcal4life
Nerd Alert!
Someone's jealous
I rarely play many games these days with so many big jobs on my 260 to catch up with...but I do get time to get some Battlefield bad company 2 in. Love that game.
But yes back on topic...Can't wait to get the evaporator done so I can see what difference the new spring pads did. I expect the 10mm drop should perfect where I want it to stand.
Old May 27, 2010 | 07:03 AM
  #48
Chappy's Avatar
AMG
Yes, cute huh? They're known as 'bumps'
One bump pads, two bump, etc. It's done so a tech can determine the pad installed by feel, without having to remove the coil springs.
Enjoy your one bump pads!
Old Jun 6, 2010 | 06:45 PM
  #49
pifcat2's Avatar
where did you get the pads? Tired of the bottoming out, I need 3's too...
Old Jun 6, 2010 | 10:18 PM
  #50
ps2cho's Avatar
E
Got them at the dealer. The guy there is cool and I think he gives me the business discounts as he always gets out the calculator and the price is like 1/2 of the list...So not complaining!
I tried a local shop who sells MB parts, but he said it was something he could not get and dealer only item.
Got my receipt in front of me:
#1 Spring rubber shim 201-321-09-84
List: $11.78, Net: $5.82
So at the very most you'll be under $25. They aren't expensive. The #3 pads are probably about the same price.
Of course, you could always buy my #3 front pads off me if you want. They are in good condition and I'll give them to you dirt cheap if you are so inclined...although the shipping may end up being the same as getting them new
