1988 300 E Fuel not reaching spark plug
Old Aug 14, 2010 | 05:36 PM
loclark757's Avatar
1988 300E, 1994 E320, 1999 ML 320, 2002 SLK 32 AMG -SOLD-, ML 350SE -REPOSSESED-
Im getting good fuel pressure at my fuel distributor and the system is priming.
However, the fuel is not being shot through the injectors for some reason...
Help is needed!
Old Aug 16, 2010 | 12:16 PM
neanderthal's Avatar
Either the distributor, fuel pipes or the injectors themselves may have a blockage.
Just because you are getting good fuel pressure to the fuel distributor, doesn't mean you are getting fuel pressure from the distributor.
Old Aug 16, 2010 | 09:06 PM
loclark757's Avatar
Ok im going to unhook some of the injector lines and see if gas comes out after I prime the system...
Old Sep 6, 2010 | 04:01 PM
loclark757's Avatar
I jumped the fuel pump relay and no gas came out of the injector line for cylinder number 6.
Is there a way to clean out the line? Could there be a blockage in the fuel distributor or something...
Old Sep 17, 2010 | 07:49 PM
loclark757's Avatar
I did not know the key has to actually be turned on for the plunger to work. It will simply not engage.
The plunger is what allows the pressurized fuel and air to shoot it to the injectors...
Im going to properly test it again tomorrow!
Old Sep 18, 2010 | 08:39 AM
David Hendy's Avatar
'97 Renntech E60RS
Pull the air cleaner off & crack the line from the fuel distributor to the injector. Do it to each one, while cranking & you will see if any of the injectors are getting fuel. If none of them are then its probably your fuel pressure regulator.
Old Sep 18, 2010 | 05:16 PM
loclark757's Avatar
Nothing was flowing out!
I just got a fuel pressure regulator from Pick and Pull it was only 6 bucks. They cost 400 brand new.
Its really dirty but the overall condition is way better than the one I have now which is all tarnished completely 100%.
I got it off a 91' 190E 2.3L
Keeping my fingers crossed...
Any way to clean a Fuel Pressure Regulator?
Old Sep 19, 2010 | 05:31 PM
loclark757's Avatar
Just put on that FPR from Pick and Pull. Still nothing has changed except the car sounds better when it trys to start.
Got another EHA Valve gonna try that...
Old Sep 23, 2010 | 06:46 PM
loclark757's Avatar
Im going to change/clean the plunger and see if it will fit back in! Then I will know whether or not the fuel distributor is good...
Old Sep 25, 2010 | 06:00 PM
loclark757's Avatar
The fuel distributor is bad! I just tested the plunger and its sticking...
Old Sep 25, 2010 | 06:22 PM
ohlord's Avatar
CALL PATRICK
ext 206 Potomac Maryland
Old Oct 1, 2010 | 06:22 PM
124 forlife's Avatar
*89 300 E -*91 300 TD -85 300SD *74 VW dune buggy
I am sorry bud,but what is a plunger? As far as you wrote you have good presure ,wich you have to measure at fuel distributor intake and return . So mining is your distributor gets fuel in the chamber conected with EHA,but if you dont have any fuel out of cracking open lines,your EHA does not leting it go.Check for the EHA voltage at harness.
Old Oct 13, 2010 | 08:12 PM
loclark757's Avatar
I got another fuel distributor as well as EHA valve. The plunger on it is good. I even checked it.
Still will not work!
The plunger is what distributes your gas to your injector lines. The plunger is manipulated by a lever which is connected to the air flow sensor plate.
I think something is messed up with the control-plunger counterforce!
Old Oct 13, 2010 | 08:48 PM
liveoak's Avatar
300 mercedes
What is EHA
Old Oct 13, 2010 | 08:54 PM
liveoak's Avatar
300 mercedes
is it possible to disassemble gas distributor and not damage it. the thing does seperate in the middle. I have not replaced any parts yet. i have the same problem the very same problem. .
Old Oct 14, 2010 | 02:46 PM
loclark757's Avatar
Do not disassemble the Fuel distributor! The only thing you should remove is the plunger! This is the mechanism that moves freely in the middle of the fuel distributor. Check the condition of it.
If the plunger sticks when moved up and down and set properly then it means the fuel distributor is toast!
You have to mark it before you take it out so you know where to screw the seal up to.
Old Oct 15, 2010 | 03:37 PM
it hapend to me this summer.No gas coming out of any pipe.Bought a used EHA,checked pressure at inlet and return of distributor,nothing.Finally I disassemble the distibutor just to find out that all rubber rings(6)on the inner plunger ,have fallen apart ,due to age I would say.Yes I tried to reassemble with some rings you can find in any auto parts store packed in a box full of different sizes.But did not work.This time gas was flying through the spark plug holes every time I would crank the engine.So I ended buying a garantie good used distributor and that solved a problem. If you desire to open yours and find a good rubber rings arround inner "plunger",you are lucky cause the other thing to check are the filters.Each single line (pipe) has its own pressure membrane and filter in small bowl like, ressed in the lower portion of distributor.Just be carefull when assembling and get enough petroleum based grease on eather side. On the rings and surraundings where it is going to sit(lower part in the center hole).Talking grease cause I ripped mine assembling it without and " petroleum based" cause it will disolwe in the gasoline. And one more wery important thing.When I opened mine I did not find any dirt at all. Wich lead me to a foulty EHA.My point is:If everything is OK with distibutor,check your EHA wich are more prone to fail than distributor itself.I would say 1:1000
Old Oct 15, 2010 | 03:55 PM
In fact there is one quick way to check it. Since EHA receives gasoline from bottom portion of distributor every time gas pump is involved,and has two o holes. One hole comming from bottom portion of distributor,another going to upper part.Gasoline comming from bottom pasing through computer regulated EHA toward upper part. So you can remove your EHA (get some clean shop rug under the EHA) be carefull not to loose rubber rings gaskets,and apply pump. IF everything is OK with bottom portion of distributor, you will see gasoline coming out on one of the EHA holes at the side of distibutor. If you have gasoline out then you know 99% that is your EHA problem not havin any gasoline on all pipes. I would check this first before even thinking of opening distributor. Hope this helps. Jack
Old Oct 15, 2010 | 04:03 PM
using a parts without a knowledge of working properly is just going to deepen your misery
Old Oct 16, 2010 | 11:09 PM
liveoak's Avatar
300 mercedes
the plunger on the bottom of the fuel distributer in engaged by the air flow flap inside the body. it is simular to a cam when the flap is drawn down by the air volume the cam or shaft on the plunger presses upward on the plunger. My question is how do ya test the ehu or heu what ever that little black valve is. I ohmed it and it's reading 25 ohms and getting 4 volts on the power plug thast would seam right but i dn't know.
Old Oct 17, 2010 | 02:09 PM
Originally Posted by liveoak
What is EHA
I gues it should be : Electro Hydraulic Actuator where computer gives different voltages according to gas pedal etc etc. I remember it was somewhere on forum about EHA .
Old Oct 17, 2010 | 02:14 PM
if you played with your EHA screwing it,and that is a cause of problem ,guys with better knowledge than mine saying: 1/4 turn is too much .
Old Oct 19, 2010 | 11:41 PM
liveoak's Avatar
300 mercedes
I didn't turn the screw on the side or whatever inside or bottom i removed it and tested it with ohm meter. i have gas pressure on all lines except injector lins so i think the eha is ok or i woud not have gas on the pressre switch coming off the top side of the dstrbutor. i think the rubber inside the dstrbutor has roted due to ethanol posioning. will take it apart this wekend for sure.
Old Oct 20, 2010 | 01:59 AM
You did not touch the brass screw on the EHA. that is good.Dont know really how much of resistance should be on it. One thing I dont understand. Having pressure at all lines but not injector lines means,you have pressure at "suply" and "return" only. OK that is confirmed .That pressure switch you are mentioned is the EHA. It is on the side of fuel distributor toward your windshield.Black box with two Stainless screws on it with alen heads.
Old Oct 20, 2010 | 02:22 AM
could not find it on this site. Go to BenzWorld.org, punch the search box and write down Eha valve. Post will come out,go to a link #9. Everything how to test Eha valve. Hope it helps.
