M104.980 won't start... i need suggestions before sending it to the crusher
Engine cranks, tacho bounces in the dash, but won't start for the life of it...
There is gas since i smell it, i even took out the plugs and left it overnight in case it was flooded.
One issue: i put an inline spark tester and the spark is orange color not the bright blue... so i think it's gotta be an ignition problem.
Questions and I need opinions what to do:
1. I just want to hear it start before doing any other work on it, so i'm trying to start the engine without the belt in place in with no water in the system, just oil. I'm asking: would this be an issue for the engine not to start? I don't think, but i'm asking all the stupid questions since i'm out of ideas.
2. How can I test the EZL? how can i make sure it's working?
3. I just want to hear it start, or at least to try to start, sputter, i don't need it to idle... what components are in play for starting this engine?
Engine harness was redone... could something go wrong? what harness components should i test?
thanks for the help... i'll give it till the end of the year, after that i'm ripping it apart
the only way i know how to test the ezl is to swap it with a working one....unfortunately.
as i said, i'm getting a weak spark... should there even be a spark if the EZL is gone?
i'm waiting for several EZLs to come in from Europe, i'll give it a try with one of those...
Let's just get the simple stuff out of the way..
How positive are you that the plug wires are all connected the right way?
Check to see if you're getting 12+ volts at the battery and 10+ volts at the coil.
I'm assuming you're using non resistor spark plugs, right? Wires already have resistance built into them, resistor plugs just give off a weaker spark. .
You're getting fuel, that's good. You have all the basics down, just go through them again.
i put back also the air filter housing to have everything plugged in, but still, the car does not want to start...
i have some spare parts to test with, but they're all stuck in europe... there's something going on again with air post and you can't send to US larger package than 400g...
if it won't sell this week, prolly EFI will be on its way onto this engine...
