'93 300E Starting Troubles
i was told by a mechanic that if the battery goes flat then the car wont start unless you unlock and lock the car several times.
you may also want to check your OVP relay behind the battery (covered by plastic). first check the fuse(s) ontop and if that doesnt fix it. you can buy a new one from Autohauz or if you are cheap, go to a JY and find one!
good luck.
You are saying "it won't turn over" and I assume that you mean "it won't start, but the starter is engaging and actually "cranking" the engine, but that it just won't "fire up". Othewise, if it is REALLY not turning the engine crankshaft and making the little thingeys go up and down up and down......then you got a BIGGER problem than the OVP!
