20" s55 wheels?
Old May 4, 2011 | 04:23 PM
midnightsaint's Avatar
2001 E320 4matic Estate
20" s55 wheels?
I have some AMG s55 wheels up here at the lot I can get for cheap. They are 8.5 in the front and 9.5 in the rear. They have a 43et offset. What would I need to do to make these fit? When I say cheap I mean cheap so if I can make them work it would be awesome.
Old May 4, 2011 | 04:37 PM
Shoomakan's Avatar
2006 C55 AMG 6 speed
I'm having heaps of trouble with my E55 wheels, and they're 18's with an offset of 31 and 35 front and rear, respectively.
At the very least, assuming the ET is good (which I have no idea of) you're gonna have to run a ridiculously thin sidewall. The overall size diameter of the tire needs to stay as close as possible to stock.
Old May 4, 2011 | 04:58 PM
Well if I got with a 255/30/20 tire for the rears its only 1" taller than stock.
Old May 4, 2011 | 06:19 PM
semis1's Avatar
'91 C124 300CE,'06 ML 500 W164, '00 BMW MCOUPE, '65 COBRA REPL.
The width of the rims is where you will have major troubles. These cars can use 7.5 and up to 8. After that it is just to wide. The offsets are about factory (42).
Now the 20" part....too big in my opinion and with 30 profile your ride will be compromised.
You will need to roll the fenders and install spacers on the front fenders and if you are lucky you will get them in but the rear 9.5...fender flares?
Hope someone who has done this will chime in.
Old May 5, 2011 | 01:31 AM
Shoomakan's Avatar
I think the fronts are more of a problem. I've got 9.5's in the rear and with a 35 offset I have no rubbing issues.
The fronts are 8.5 with an offset of 31 and they're killing me. And I've rolled my fenders.
A tire sidewall width of 20 will essentially make your ride so that you can tell if the quarter you've run over was heads or tails.
Look, you wanna try, try. None of us can stop you. But I'm telling you, I don't think it'll work. Not to mention that your tires will look small on the rims, very little rubber. Some like that look, but I don't.
Post pics of the rims, too. I don't know what they look like.
Old May 5, 2011 | 03:18 AM
ZorroAMG's Avatar
Enzo, my Benzo
20's regardless of ride height and sidewalls will make your W124 sit WAYY too high off the ground.
If you want the SUV look, be my guest...
Old May 5, 2011 | 05:52 AM
DW124's Avatar
300TE s124 E320 w124 project
Is it rubbing on the cladding,if so do you have spacers fitted?
Old May 5, 2011 | 10:03 AM
Shoomakan's Avatar
It's rubbing on the fenders when I take corners, and with sudden dips in the road it rubs on the inner cladding as well.
My tires exceeds the fender width by about a centimeter. :P
I'm taking it in to the bodyshop in a couple of weeks to flare my fenders. After that, I'm getting stiffer shocks and springs. It should be fine then.
If not, I will shoot myself. :P
Old May 5, 2011 | 10:58 AM
Sounds like I will pass on the 20" wheels. This girl is my daily driver. And with our local streets being as bad as they are. Thanks for the help guys.
Old May 5, 2011 | 11:57 AM
RHW's Avatar
RHW
94 Wagon and 94 Cabriolet
17s rock.
Shoomaken, I had a residual rubbing issue a few years ago after rolling fenders and a few contortions...tightening suspension alone solved it, had a worn bushing in the rear. Maybe try that before the fender flare work.
Old May 5, 2011 | 07:10 PM
Jan AMG's Avatar
The best or nothing
Don't put anything bigger than 17"
Old May 5, 2011 | 07:58 PM
ZorroAMG's Avatar
Enzo, my Benzo
Why not?? LOL!
I've run 18's for the last 8 years and they are amazing, run just fine and look far better than 17's
Old May 6, 2011 | 05:39 AM
Shoomakan's Avatar
RHW, I agree that stiffer suspension will greatly aid my troubles.
But like I said, the tires exceed the fender width slightly, so if the car is loaded and I take a corner, it'll still rub, stiffer suspension or not.
My goal is to have 4 people in the car doing whatever I want and it NOT rubbing no matter what. I feel the only way to achieve that is by doing both suspension and flaring. And like I said, if that doesn't work, I'll shoot myself. :P
Old May 6, 2011 | 06:23 AM
DW124's Avatar
Use the spacers on the front mate
Old May 6, 2011 | 08:59 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
A few more mods are required as per the pdf. along with the spacers that Dash has mentioned..
I fabricated the spacers from teflon round stock..cut to thickness and drilled the center screw hole..
File Type: pdf
Old May 6, 2011 | 09:09 AM
Shoomakan's Avatar
AMG Dave was kind enough to send me those links.
I know what to do, it's just annoying that I didn't think of all this before I bought the damn things.
I've definitely learned my lesson.
I actually own a machine shop, so I can do all the fabrication in house. Now who wants to come over and give me a hand?
Old May 6, 2011 | 11:26 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Your own machine shop you say?...
Feel like fabricating long-tube headers for the m104
Old May 6, 2011 | 05:16 PM
Shoomakan's Avatar
I've got the facilities, NOT the experience.
Old May 11, 2011 | 08:46 AM
fefo25's Avatar
2010 C300 Sport 6 speed Steel Gray
Originally Posted by RHW
17s rock.
Hey, is that a 300TE? I dont know anything about these cars but I love the look. I know someone selling one, just want to know what Im getting into first.
