Can you tell me...
Old May 10, 2011 | 08:48 PM
midnightsaint's Avatar
2001 E320 4matic Estate
Can you tell me...
What this little led does. It never lights up. And I have no keyless entry.
Old May 10, 2011 | 08:59 PM
190E 16V's Avatar
1987 560SL
Looks like an LED to say MB central locking with alarm engaged
Old May 10, 2011 | 10:07 PM
So I can't find a central locking button. Like in the later modles.
Old May 10, 2011 | 11:36 PM
190E 16V's Avatar
1987 560SL
It is only activated by the trunk and door keys. The locks alone can be closed from inside by pushing down the knobs on the top of the door panel.
Old May 12, 2011 | 04:27 AM
Greger-meister's Avatar
C32 AMG
It looks to me like the previous owner added an aftermarket security system (and then removed it, because you said you don't have keyless entry.) I had that on a pre owned BMW, it had remote start, alarm, keyless... the works. Whom ever installed it, drilled a little hole in an unused plastic cap like that, and put in a little LED.
Old May 12, 2011 | 07:28 AM
PaulX608's Avatar
2011 VW cc, 2004 ML350
Mine works. Factory alarm on a '93 400E. Lock the doors with the key to arm the system. May have to look in through the window when it's dark to see it blinking when armed.
Old May 12, 2011 | 10:18 AM
190E 16V's Avatar
1987 560SL
+1 above. Looks like a factory alarm LED, on north american W124's from 1993-95. No doorlock/unlock button inside. Alarm/central locking activated by key in doorlocks. Perhaps yours is disabled, or an aftermarket remote was added to activate the factory system.
Old May 12, 2011 | 11:47 AM
edcarls's Avatar
97R129-01W163-94E320-93500E
Originally Posted by midnightsaint
It never lights up.
That's what I thought also. Then I remove it and cleaned the red dot from behind. Now I can see it blinking when I lock the door. The red plastic dot is so small that you can barely see it blink. It's best to test it inside a dark garage.
To test if you have an alarm; put your windows down, get out of the car and lock the door with your key, then reach in and open the door using the internal door lever. The horn/alarm would sound off if your car is so equipped. To turn the alarm off you need to put the key to the ignition and turn it on and off.
My 94 is originally equipped with factory alarm without keyless remote entry system. I installed an after market keyless entry system and my factory alarm still works. I'm most certain that your 95 has factory alarm.
