Window streaks from Hades!
There are cloudy (milky?) streaks on the exterior of my rear window that just will not be obliterated. Following the advice on threads in the detailing forum, I've used distilled water, isopropyl alcohol, Stoner's Invisible Glass, lint-free paper towels, microfiber cloths, clean soft cotton cloths, and so on. Many cleanings over many days - and still the streaks persist. In the past I've applied RainX to the window, but I don't think that could be the cause, as I've applied it at various times to all of the exterior window surfaces, yet only the rear suffers this problem. Has anyone ever had a similar problem and found a solution? What could possibly be causing this problem?
Thanks, Mark
If that doesn't work then apply a cleaner wax to the window..
The slight abrasive in the cleaner wax should remove any streaking...
Cleaner wax is a good method on all windows except the windshield.. !
Sometimes the layers of glass delaminate around the wires, looking "milky".
My car has started to do that at the edges. Others have had this problem too.
Thanks, Mark
The newspaper trick doesn't work anymore since they went away from the old inks (which were actually fine abrasive media) to soy based inks.
RBYCC, if I try using vinegar (I assume the white kind from grocery stores), is newspaper a necessary part of that technique? All of my local papers use the newer soy-based inks, so the older abrasive ink isn't available. Could vinegar just be applied wth a cotton cloth? If so, I could hold my nose and try that out...as long as my car doesn't smell like a salad!
Saijin, did you actually use acetone for a similar problem? Any issues with it hastening delamination?
Thanks to everyone for helping out!
Both cars had a serious film/fogging on the front and rear windshields, the acetone treatment cut through it quite easily and left the glass as clear as it could be.
Delamniation is a physical process that occurs between the two layers of glass. Unless you somehow managed to get the acetone between the two, I doubt seriously it could cause any harm that way.
I'd venture that you should try the other less... corrosive treatments before you try this. Its a great last resort, but there are other treatments that should do the trick that carry less risk with them.
I didn't rinse afterward, even with distilled water, fearing that any subsequent step was more likely to renew the problem. Of course I didn't really consider that vinegar, applied in a hot enclosed garage, would utterly destroy my olfactory sense. What we dislike in scents surely is very personal...but to my nose, vinegar is one of the foulest stenches on God's green earth. Baking in a vinegar-ridden hothouse of a garage overnight, I can only shudder to think what my baby will smell like tomorrow! I may be posting a new thread soon, pleading for help with exorcising the horrid pong.
Guess I'm out of touch with current newspaper inks...
If you want to neutralize the vinegar, wet a cloth and put a bit of baking soda on it..
Rub the window down and it should remove any of the acid residue left by the vinegar...
