excessive oill consumption
The most common place to lose it is a leaking head gasket. Everyone on this forum has or will have to deal with a head gasket leak. The only question is when. Check for oil under the car after parking for a while.
A quart in 500 miles should produce some visible smoke out the tail pipe. You can try the following: Have someone follow you. If the car smokes when you let off the gas and decelerate, it's the valve seals/guides. If it smokes when you step on it, it's the rings. A compression test by your mechanic (with and w/o oil in the cylinders) will be very revealing as well.
If it's a leak and/or the valves seals/guides, you will able to kill two stones with one bird. If it's the rings and/or low compression, a good, low mileage used engine might be a viable option. I would really only consider either if the car is in otherwise very good condition (especially the engine wiring harness).
A wise man once said that that there is nothing more expensive than a cheap Mercedes.
Peace be unto you, too.
- FD
