w215/220 wheels on a w124?
I believe they are 17x1/2 +46 offset
I was going to shoot for 18s but figured to would by way to big and a not so comfortable ride...
They are going on this
And the wheel bolts on the S class cars have a bigger diameter, 14mm vs 12 mm.
As for length. check how much of the wheel bolt extends beyond the back of the wheel and aim for that approximate length.
I think that offset would give you problems clearing suspension.
Not sure if I will get these wheels because I don't want to run spacers at all.
Perfect setup would be a 17x7.5" in the +30 offset range. No spacers, no fender rolling. You can also use a 18x7.5" wheel (same offset range) but that size is a bit more of a challenge to find.
Maybe monoblocks but the color wheel combination is pretty darn nice !
Here's a thought replace the pedestrian gunsite with the flat MB badge - actually transforms the look quite a bit !
My signature picture has the star but in life it now only has the flat badge.
Like the wheel ideas - as you say finding them is half the issue.
With AMG2 that would be one sweet lady you have.
Whats with the coupe in the background ?
Update your profile also - what cars and location.
But tidy her up.
Unless that photo hides untold rust etc the outside looks really good.
Personally I would make the 560 the weekend ride and tidy the 300 up as a daily.
I know the fronts will fit, but I am slightly worried about the rears. If it is an issue would a 225 or 235 tire for the rear be okay to clear the fender or would I need to roll them?
Also does anybody know the bolt diameter for a w202? is it 14 or 12?
The alloy wheels for the Mercedes 202 series use a PCD5x112, centre bore 66.5mm and M12x1.5 bolt thread.
My fitment is
C CLass 10 Spoke 17 inch - Staggered 17x7.5" & 17x8.5"
Falken Ziex Ze-912 Tyres - 225/45 ZR17 & 245/40 ZR17
But the 300CE also has quite a large camber at the rear so the top of the tyre falls in at the top.
If it's not lowered and you get a low profile tyre on them you should be a-ok.
Its a wide wheel at the rear, AMG used to modify the wheel arch to fit them with 245/45's on them.
I would think you 235/45's would fit but you might be able to squeeze 225's on.
Best check with a tyre place as some 235's can actually come out higher than 225's !
These are the wheels your talking about ?
http://www.alloywheelsdirect.net/mer...g_ii_wheel_192
What is your offset on the rear? 30 also?
Here's what the camber on rear is like on the 300CE !
It increased from this as the vehicle was lowered.
Not sure if the sedan also had the 1 degree or not.
I am guessing that if u have a regular 124 u can just run 235 up in the front and 255 in the rears.
