cracked fuel tank
I removed the gas tank today and i found that it has imploded, at least 1gal worth and formed a crack at the crease. It is only visible from the back side, between the rear seat and tank. I used some developer over the entire tank to expose any other cracks, but i did not find any, though I wouldn't be surprised if more formed over time from the indentation. I plan to dremel out the 1/4" crack, and tig weld it. Pictures tomorrow.
My questing is this.
Is this a common problem with running a 1995 E320 completely empty?
Or is the evap canister definitely a culprit?
How can i test this on the w124?
Where the hell is it?
the problem is the REGENERATION VALVE replace it on new installation $30.
if you have the tank out it will be on the bottom left side of tank hose runs forward to charcoal filter in front left wheel well
had this problem tank collapsed only indication that something was wrong was a vacuum on gas cap when I opened to put in gas
go buy a junk tank I paid 70 for a tank
Is this the "Regeneration Valve"? (its a one-way check valve, that broke on removal.)
Note: this tank is thin, and welds like garbage. It seems to be galvanized, and I think its un-weldable, even with silicon-bronze filler.
your tank did not collapse very much
when mine did this it would not take any more than 2.5 gal of gas.
it was visible when i removed the vanity panel in the trunk.
anyhow do not try to repair get a tank from junk yard
get a regeneration valve on ebay and a NEW gas cap.
been there done that
again for others out there when you hear a VACUUM when you remove your gas cap do not hesitate change the regeneration valve.
