How to remove exterior lower door panel?????
Old Oct 18, 2012 | 08:01 AM
Euro_style_21's Avatar
Does anyone know how to Remove Lower Exterior door covers On a 94 e320 sedan. I'll put a picture up. It's the lower light grey pieces.
Old Oct 18, 2012 | 02:21 PM
PelicanParts.com's Avatar
SPONSOR
You can start by unclipping the bottom ledges of those panels, they should pop out with a flatplade screwdriver. The top portion of the panels are held on by hinge-like clips which simply unhook once the bottom half is loose.
Old Oct 18, 2012 | 02:28 PM
Saijin_Naib's Avatar
1990 300ce 24v I6
Caveat: The clips are likely very brittle and can/may break. Make sure you have a source for new clips before you attempt to remove the panels.
Old Oct 18, 2012 | 04:50 PM
Thanks for the help guys!!!!!
Old Oct 19, 2012 | 04:57 PM
SPONSOR
+1, take your time!
Old Oct 19, 2012 | 05:20 PM
semis1's Avatar
'91 C124 300CE,'06 ML 500 W164, '00 BMW MCOUPE, '65 COBRA REPL.
On my 300ce there was also a screw at the bottom edge, at the end of the door. Check and make sure your sedan does or doesn't have one.
Old Oct 21, 2012 | 02:25 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Originally Posted by Saijin_Naib
Caveat: The clips are likely very brittle and can/may, will, break. Make sure you have a source for new clips before you attempt to remove the panels.
Fixed.
Caveat: The clips are likely very brittle and can/will, break. Make sure you have a source for new clips before you attempt to remove the panels.
Fixed.
