power window
Old Apr 24, 2014 | 10:25 AM
ElieSednawi's Avatar
w124.031 300e 1991
power window
Hi
this might be silly but i have to ask
my driver side window doesn't go all the way down (auto mode), i know that there is a way to program it.
any idea's
Old Apr 24, 2014 | 10:50 AM
eurosportlines's Avatar
MB S550
power window
Hi Elie
Push the button to lower the window and keep pressing it for 5 more seconds. It should do the work. Then Try it.
Old Apr 24, 2014 | 11:00 AM
w124.031 300e 1991
Originally Posted by eurosportlines
Hi Elie
Thank you for your quick reply
Sadly i tried that before and didn't work
Old Apr 24, 2014 | 11:12 AM
MB S550
Hi Again just disregard previous comment, my mechanic says that vehicle does not have memory system in the windows for auto mode, I didn't see the type of vehicle you had.
Old Apr 25, 2014 | 02:00 AM
w124.031 300e 1991
Originally Posted by Plutoe
Simply put the key in the door---turn to lock and hold---what happens??
thank you for that, that was quite interesting i din't know this trick before. if you have others please share it.
unfortunately this didn't solve my problem, my problem is that the window doesn't go all the way down with a single push on the bottom.
Old Apr 25, 2014 | 07:30 AM
w124.031 300e 1991
I guess the problem is that we all have different learning styles,I like to read and learn, like in this case I read the owners manual and double checked with WIS.There are no secrets just ignorance!!
Additionally, when you re read my post, I asked a question----"what happens" any chance of answering the question, because I was trying to determine if the window went up and down all the way with the key in the lock!!! Just a simple yes or no will do.
Hi
yes all the windows including the roof went up, non of them went down
Old Apr 25, 2014 | 07:37 AM
w124.031 300e 1991
With the windows up put the key in the lock----now unlock then hold---what happens repeat what happens??
nothing, i tried
Old Apr 25, 2014 | 08:13 AM
w124.031 300e 1991
That is good nothing is supposed to happen----now with the drivers side window all the way up(this is a two part question) what happens when you push the switch but not all the way??---re close the window----what happens when you push the switch all the way down??
if i understood right!!!!
1- it goes down till i stop pushing.
2- this is a bit tricky, fist try the window goes down while the bottom is pushed (no auto function), i tried for a second time (but after i locked the doors and unlocked them), the window went down like 3/4 and stopped.
Old Apr 25, 2014 | 08:19 AM
w124.031 300e 1991
With number1- were you able to keep repeatedly pushing and close the window all the way??
yes
Old Apr 25, 2014 | 08:29 AM
w124.031 300e 1991
You have a bad switch!!
thank you for your effort
