1993 300E 2.8 ECU Problem
Hello,
I am replacing the wiring harness in my 2.8 and my mechanic just melted my ECU. I was wondering if anyone can help me with the compatibility of my ECU with others, since it's quite a rare car. Chassis is: WEA1240281B989414. It's a 1993 300E 2.8 with Cruise Control, 4 speed auto and no ASR. US Spec car. I think part number might be A018 545 65 32 but I am not sure since the car is not close to me right now. Also, it's a VDO ECU. Could a Bosch one with same part number work?
In EPC there is also a ASR Control Unit but since my car has not ASR I should not be worried about that right?
Really would appreciate any answers, dont have 1000 bucks to spend on a new one!
As your car engine been changed 300E are 3 litre as mine is a 260E = 2.6 litr. Not sure about the engine size the number you gave on your post is for a E220 - 2.2 ltr = 0261203502 0261203502 A 0185456432 but untill i know the engine
type, to search its a no go at the moment .Whats the engin type ,like 260e is M103 and also they fit a M104 is yours the M104?
Hey there, I am in Portugal and I got one from the UK. Far from Texas lol. After I replaced it it was all same symptoms, in the end was a crappy 10 dollar ignition coil plug that was making my car misfiring! Spent 1500 before that!
My car was misfiring like crazy when hot. With ignition in position 1 and if I touched harness I could hear click's everywhere like injectors spraying and throttle body opening and closing. Replaced it and I though i melted my ECU in the diagnosic process. Well, I was wrong
No diffrent symptoms mine always misfires from ignition position number 2 weather cold or warm and my ignition coils are good and my wires and plugs are less then 5k miles old
https://www.google.pt/search?q=coil+...-kJ_X2WUjtIuM:
All my stuff was testes and all was ok. I even testes coils in a cold and hot situation, and outside the car performed fine. I found the culprit just by swapping parts until I got it finally. I did all the major's before: ECU, engine harness, ETA, new injectors, MAF, CPS, coil pack, plugs, plug cables.. as I mentioned, I replaced almost everthing and such a small thing was making my car run like crap.
