Brake Pulsing
If it is the front, do you feel it through the steering wheel too? And, have you had the rest of the front steering components and suspension checked out?
More likely than not though, what you have is a warped rotor. I had the pulsing through the pedal, and felt it in my seat, driver's side rear. Visual inspection of the disk showed it to look fine, nice and smooth, but once I put a dial gage on it and checked the runout it was obviously warped.
Solution: Replace both rear rotors and pads. Couldn't believe how cheap those rotors were. I have a set of rotors and pads waiting to go on the front, I'm just waiting for either the brake sensor lights to come on or for those rotors to get warped. Remember, the MB rotors are not designed with a whole lot of thickness on them. Less heat capacity due to there physically being less metal. They can't be turned either, just replaced. I think that the front rotors are less prone to warping due to their construction.
I have heard of rotors getting warped due to driving and getting the brakes good and hot, then washing the wheels right away once you get home. (Buddy was a real particular neat freak about brake dust on his wheels.)
My ABS is very over-active.
Mine does it, but there is no fault with the ABS, discs (rotor).
I've had mine checked both by my mechanic and it went through it's MOT a few weeks ago and the brakes are perfect. (MOT if your not familiar, is an annual government test of car safety, brakes suspension etc. coming in for close scrutiny). The inspector did tell me that the bushes on the end of the anti-roll bars were not long for this life.
You cannot tell which one is faulty and they are very expensive. If this sounds more like your problem, have it diagnosed.
