OIL Drain plug
Old Dec 8, 2004 | 07:28 PM
Brian Felts's Avatar
E 320
OIL Drain plug
Hey all I am back with another question. I am doing to first oil change on my E 320 and I found the plug is pretty striped. I have already ordered a new one because there is no way I would reuse this one. Now how in the world can I get this thing out. Its VERY tight and some ends are rounded and some are not.
Thanks for the help!
Brian Felts
Old Dec 8, 2004 | 07:50 PM
13benz's Avatar
98 C-230
if you can still get a wrench or socket on it use one that is six-sided, and fits over the head nice and tight. a shot of wd40 on the bolt would be a good idea too, if you can't get enough leverage to turn it try an impact wrench, or a cheater pipe over your breakover bar. or hit the wrench with a rubber hammer. (make sure it don't fly off) if it's too rounded to get a wrench on anymore, i would put the vice grips on it super tight, as tight as you can get them, and hit it loose with a rubber hammer. make sure youre going counterclockwise
Old Dec 8, 2004 | 08:42 PM
E 320
Hey cool Ideas.........those were on the line I was thinking but I am at a stop until I get my new drain plug in.
Brian
Old Dec 8, 2004 | 08:50 PM
electric blue's Avatar
Oil Plug
Sure it's more stripped then it is tight. Make sure once you do remove it that you replace the copper washer with a new one and dont torque the plug more then 26ft lbs.
Old Dec 8, 2004 | 09:25 PM
E 320
Yeah I don't know who cinched it down so tight. The car has a extensive service history from Mercedes and its a 95 with only 92,xxx but I hate running into things like this.
Thanks all for the help!
Brian
Old Dec 16, 2004 | 01:32 PM
E 320
I got it. I tried the Vice grips and it didn't work. I then went old school Chevy mechanic and used a pipe wrench ( This worked many times when I work on Camaros) and it didn't work so I got out the sears tool for striped bolt heads and It didn't work with the socket wrench turning it. I got mad got out the Inpact gun and hit it with it and boom it came out quick and easy. YOU NEED THIS TOOL!
Brian Felts
Old Dec 17, 2004 | 09:13 AM
Jim's500E's Avatar
You may want to consider a 'Fumoto' drain plug for easy oil changes...they sell here in the states also.
www.fumoto.com
Old Dec 17, 2004 | 04:47 PM
E 320
The link didn't work....is it anything like the fram quick change one. I got a standard plug from Autohausaz.com for less than two dollars but the fear of how bad that plug was rounded got me. Autohausaz I will say was a fast shipper and good to deal with.
Brian Felts
Old Dec 17, 2004 | 06:18 PM
Oil plug
Brian!!!! As long as your using the right socket to take the oil plug out and your using the right torque to replace it, the plug will last a life time. Just remember you need a 13 MM socket and replace the copper washer everytime you change your oil. Also do not tighten the plug over 26foot lbs.
Old Dec 17, 2004 | 11:23 PM
E 320
Yeah good tips. The E 320 I puchased had an extensive service history with MB. I was very suprised when I went to change the oil and found a drain plug so messed up. I can't say for sure a dealership had done it but according to the service records it must have been. That is why I do all I can on my own, with the help of you guys on this car.
Thanks to all
Brian
Old Dec 20, 2004 | 09:39 AM
Jim's500E's Avatar
Hmmm...link worked for me....try searching some more (google, etc)....several US places sell them....its a neat little spigot thing....an Audi bud turned me on to them...about $20; no tools needed to drop the oil.
...or just be careful with your new , regular plug ...nothing wrong with the old fashioned way of doin' it either.
