Differential Fluid
Old Dec 17, 2004 | 06:11 PM
Nick_M_51988's Avatar
1992 400E (86 300E, 98 S420) - Retired
Differential Fluid
changing my differential fluid today, but was wondering how much i should replace it with. Any Brand recommendations?
thanks alot.
Nick
Old Dec 20, 2004 | 10:35 AM
Jim's500E's Avatar
I like Redline synthetic....got rid of the 'howl' that my 190E 2.6 and 500E once had.
OEM stuff is just fine though.
Old Dec 20, 2004 | 10:47 AM
E320Star's Avatar
2000 E320 Sedan
Use MB authorized only to avoid any issues.
Old Dec 20, 2004 | 11:40 AM
Jim's500E's Avatar
Thumbs up
Very true...MB does recommend ONLY their stuff...
I think ALL manufacturers prefer you use their stuff, for what gain is ceratinly debatable...more probably linked to money and quality control...which shouldn't be a problem if you do your homework and choose a decent aftermarket product that has been proven to be as good if not better than OEM.
Old Dec 22, 2004 | 07:14 PM
newnewkid's Avatar
How do I change the diff. oil
Nick, Is it a easy job to change diff. oil? How did you do it? Thanks.
Old Dec 23, 2004 | 01:23 AM
yes it was fairly simple. if you can change oil you can do this.
i took the pan off to remove some sludge and i also had a leak.
i scraped off all the RTV sealant and replaced it. Make sure you do this.
i just drove it up on some ramps to do this. it was easy to do i i feel some extra ponies that i didn't have before. i highly recommend this.
i used some Mobil 1 Fluid 85W-90 weight. NON synthetic. mercedes DOES NOT recommend using synthetic. did it along with an oil change in about an hour.
Old Dec 23, 2004 | 01:24 AM
oh and FYI the mercedes differential oil is Mobil 1. same as the oil. mercedes uses Mobil Products and slaps their name on it.
Old Jan 3, 2005 | 11:51 AM
nrddct's Avatar
91 e30 318is, 92 e30 mtechnic
the users manual says to use 85w 90, but redline only makes 75w90. Do ya'll have notice any problems?
nrddct's Avatar
what about power steering fluid?
Old Jan 4, 2005 | 03:05 AM
I'M not sure, but if were you, talk to your stealer-ship. find out for us. most mobil products are approved by mercedes. but i wouldn't take a chance.
also on synthetic oil, i know it has been approved by mercedes to use it as
Brake Fluid
Motor Oil
and tranny oil (only on 90-93 models for some reason.)
