another shock question....
the car has the stock suspesion set up (shocks and springs)... with about 78k miles on it......... im debating on Bilstein HD or bilstein comforts......... which one would give me the smoothest ride possible? also, would there anything else i should have changed while this is being done? i havent shopped around yet but... what would the ballpark figure be for parts/installation?
-thanks
carino
So do you plan on lowering it as well. Don't really recommend the Bilstein's HD...Get the Bilstein Sport shocks if anything. I don't know how much parts and installation would be but for me it would cost 600-700.
If you are going to lower it, H&R Springs with bilstein sports.
I have heard the bilstein comforts are too soft. The HD's I have heard a lot of people like actually. a little stiffer than stock from what I can remember.
THe problem could be a bad bushing somewhere int he rear suspension.
Look at the shocks, if they look kind of wet, they are leaking and should be replaced.
It could be one of the bushings in the multilink suspension.
Ashman
Ashman
i took the car to the dealer about a month ago and had them look at the breaks.... said they were fine but could use a break fluid flush... so thats what i had done... i havent had the rear suspension looked at... bushings and all.... as far as looking to see if the shocks are wet... i havent looked... ill do so..
as far as lowering the car... im not planning to do that.... all im looking for a smoother ride..... the factory shocks were great... and im sure 10 years ago (hopefully) they were among some the better technology shocks on the market of the time... assumming shock technology has changed... what im looking for is something that is comparable to date.. but newer... (if that makes any sense)
ive read a number of people suggest HD.... so i guess that may be the way to go... is there anything else i should also get changed? if i get the shocks changed... should i look at getting the springs replaced also?
thanks for you guys' info-
carino
I opted for a sportier and lowered car, so I went with the Neuspeed springs (they are simply rebranded H&R's) and I havent done the shocks, but the ride has been still good with the stock shocks.
I'm getting the bilstein sports soon on my car.
Since I put on the AMG hammer wheels, I definately need to stiffen up the ride a little . it will help with the minor rubbing I have, plus I have been meaning to do the sport shocks for a while, just havent gotten around to doing it.
AshMan
OliverB
it sounds like the same exact problem im having... do you think my bushings are worn at 78k miles? and sorry, what do you mean by 5 each side?
thanks to everyone for your advise.... im probably not going to get this fixed for another month or so.... ill let you guys know what way i go..
thanks again
carino
thanks
carino
thanks
carino
I installed the shoks myself, it took me an hour, the 4 shocks cost me $450
