amps suck too much juice
Old Mar 9, 2005 | 01:40 AM
mysticblu999's Avatar
Mercedes AMG
i am running one of the mb quart 4channel amps right now. im using it to run my mids and highs and one small sub at the moment. when its on it sucks so much power it slows my car down alot. im gonna add another amp like it but a mono amp to run 2 of the big mb quart subs. how much slower will this get?! hahhah not too worried about it but thinking of a few things... another battery or a capasitor. i don't really think a capasitor will really do much so i was gonna try 2 batterys. yes i have already checked out optima batterys and the one im using is about the same. (they say the just last a little longer)any one ever have this problem?
Old Mar 9, 2005 | 08:33 AM
michakaveli's Avatar
E300
Sounds like also your alternator might be weak.
I have read elsewhere that the 143A and 150A alternator from the S420/430 engine's will also fit. Don't quote me but I did look into it. I haven't done it myself as I came into a crisis and needed to get my car going again so I went with an OEM replacement.
Old Mar 9, 2005 | 05:02 PM
Mercedes AMG
ohhh.... i just put a new one on... didn't help much... my old one wasn't working at all.
Old Mar 9, 2005 | 05:37 PM
The Godfather's Avatar
4 wheeled car.
separate battery is always good, but some good caps won't hurt.
Old Mar 10, 2005 | 12:31 AM
Mercedes AMG
think i will try the battery first. anybody ever ran 2 batteries?
Old Mar 10, 2005 | 12:41 AM
4 wheeled car.
Yes. A few members here have.
Old Mar 10, 2005 | 11:05 AM
zx11blade's Avatar
2001 E320, 2008 E63 AMG
Cool
You should have someone check your alternator to see if it can handle the amperage. You will find that your probably need at least 170+ amps. Why put in 2 batteries when the alternator is struggling to handle one. As for the capacitors, they will only keep the voltage level form dropping too much, and again if the alternator can't handle the current drain it will make the voltage. Also have someone check all the connections especially the grounds.
Old Mar 10, 2005 | 02:27 PM
Mercedes AMG
how did that work out?
Old Mar 10, 2005 | 02:28 PM
Mercedes AMG
anything i can do to my alternator now? its brand spankin new!
