Removing 1998 E430 ECU for Chip Tuning
Send the whole unit, do not open it up.
It's a little difficult to pull the connectors out and also to pull the box out but be patient. Again, the 2002 may be different but I doubt it.
Good luck and let us know how it goes and if the chip gets you a good gain.
www.upsolute.com
Regards
Richard
Ben
Did you get the performance from the chip that was promised? Does replacing the stock chip with the Wettenhauer replacement part void any parts of the MB warranty? Is there anyone on the board who can vouch for this chip? Has anyone here really obtained heightened performance utilizing the new chip?
I am also looking into the UpSolute offering. Theirs is different in that they will reprogram your chip and resolder to the ECU; and they do this through a local distributer. You do have the option of going back to your orignal program however they would have to de-solder the chip, reprogram, and then re-solder back in. It is cheaper than the Wetterhauer solution and you do not have to remove the ECU, send it in, and wait for it to be returned.
removing the ECU:
re-installing the chip:
If you're interested in my Upsolute experience, here's a link to the thread at Benzsport:
Upsoture Chip on E430
Good luck! I think $ 4 $ Upsolute's a good deal.
click on the link in my previous reply post. Just briefly, the upsolute chip gave my '02E430SE a real good feelable gain. My GTech Pro recorded about a 10HP gain at the RW. Dropped my 0-60 from 6.73 to 6.2/6.1. It feels like running 1 gear low all the time, or nowadays, feels like how the engine was with the climate control in "E" when the A/C is really on. Does that make sense? IOW, I think it's worth it.
The ECU is really not that difficult to remove. The wire harnesses are just tight, and you to figure out the plastic locking tabs. When the harnesses are out, you have to jiggle pretty hard to free the ECU. Jiggle straight up. It's the one closest to the firewall. Careful with the cover screws too. You don't want the stealership to know you've been fiddling in there.
