PICS: Bi-Xenons @ Night
Old 08-13-2005, 11:15 PM
Highend's Avatar
C219 CLS / W220 † / W211† / W210 E55 † / W210 Brabus † / Hamann 540i † /
Fogs are off, its a reflection because my fogs are pretty bright. They are the all clear euro style ones
Old 08-20-2005, 08:56 PM
jadakiss64's Avatar
Bi-Xenons
How can I get a pair of these for my car?
Old 08-21-2005, 05:05 AM
Ben'z's Avatar
E320
Zam2000!
Old 08-23-2005, 05:16 PM
The Godfather's Avatar
4 wheeled car.
Bixenon doesn't mean that there are two separate projectors with two separate bulbs. I have retrofitted W211 bixenons in my car. All it is is a projector that has a metal flap in front of the bulb. In a non bixenon application, that metal flap is there to stay. Butw/ bixenon, that flap is hooked to an actuator, which is triggered by the highbeam switch, and then drops down to let all the light out, thus giving high beam. There is no separate bulb to ignite.
Old 08-23-2005, 11:21 PM
midget fidger's Avatar
E550 Coupe
oh wow...i didn't know that!
Old 08-23-2005, 11:27 PM
Whitey's Avatar
98 W210 Advantgarde
Your regular center hi-beams still "ignite", but that's mainly for flashing purposes.....but you're correct on other matters. Sources tell me commercially produced bi-xenons for the aftermarket will be introduced very soon........
Old 08-24-2005, 12:57 AM
  #32
Highend's Avatar
dont matter, mine will still overpower all others
Old 08-24-2005, 04:22 AM
  #33
4 wheeled car.
My bixenons are ridiculously bright in highbeam. It lights up tree tops some 20ft high and the road so wide....
Old 08-24-2005, 04:26 AM
  #34
phatstyles's Avatar
e-klass
GodFather - Did you retrofit the lens yourself? I just picked up some new headlights on ebay. Can you give me details if so.
Old 08-24-2005, 04:55 AM
  #35
4 wheeled car.
Yes I did it myself. It's very straight forward. Get rid of the cheap lense/projector, line up the new one in there. You gotta jerryrig it with washers or use epoxy. You'll see. It's because the holes dont line up. And then the two wires (positive and ground) for the high beam actuator needs to be tapped into the high beam wires, so that when you pull for high beams, it activates the flaps as well. That's pretty much all there is to it.
Old 08-24-2005, 03:58 PM
  #36
jadakiss64's Avatar
Can someone point me in the right diection on how to purchase these type of lights for my 97 W210
Old 12-27-2005, 11:12 AM
  #37
fireice's Avatar
500E
What do you need for bi-xenons?
If you already have xenons W210, what do you need to make bi-xenon? An entire W211 light assembly or just the bulbs? Any tutorials?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Quick Reply: PICS: Bi-Xenons @ Night
