Trunk Lid Won't Open. Help please
such as what methods have you tried to open the trunk? Did you try the
mechanical key? cabin switch? Smartkey...etc etc....
you can zero your focus on the cable leading to the trunk latch. Verify
that it did not get jammed or disconnected. Dont think you can access
via the pax compartment; prob fuel tank or metal plate there.
I'm intrigued that the trunk lock access is inoperative. I can see where
the electrics can be snafu-ed, but I'm left scratching my head wondering
what you jogged loose to inhibit the mechanical system.
more. so something else is keeping it closed. any room to get leverage
and put upward pressure to see if it can be persuaded to come up....
while someone else turns the mechanical key. no....dont use a crowbar. ;-)
Then, try closing it. This is pushing down to close it and then open it.
I had the same problem. The latch was open but not fully. I "re-close" it from a close position of the trunk and then, voilá, it opened.
Hope it works. I know it is frustrating.
The locksmith, a good one, could be a right move.
Thank you
Trunk less
