Taking out interior wood trim help???
Old Oct 8, 2005 | 06:07 PM
blackstunna's Avatar
i am trying to help a friend take out his wood trim on his 97 w210, how would i go about this? i don't want to break anything...
thank you
Old Oct 8, 2005 | 10:31 PM
sbarsap's Avatar
13 Lunar Blue GL550, 06 Imola Red BMW X5 4.8is, 04 Gold Honda Ody
Which wood trim?
Old Oct 8, 2005 | 10:53 PM
raymond g-'s Avatar
99 E320
see if this helps -----> edsoto
Old Oct 9, 2005 | 01:45 AM
Alexbenz's Avatar
Sean's Sister--
i think blackstunnas talking about all wood trim.......mainly hardest one is the center console and the top portion of the dash
Old Oct 10, 2005 | 12:12 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The doors are easy..remove the door panels..dash wood simple remove the combi and the wood will remove easy..center console..easy...
Replaced all my wood in a afternoon..to Black Birds Eye Maple...
Old Oct 10, 2005 | 04:00 AM
whats combi? can i take out the trim on the doors without removing the panels?
also in the center, would the radio/control climate have to be pulled out to take it apart?
Old Oct 10, 2005 | 08:32 PM
Combi = Instrument Cluster
No The Door Panels MUST be removed to remove / change the wood on the door
yes the climate control and radio MUST be removed to remove the center wood ..
Old Oct 12, 2005 | 12:08 AM
mbzmike's Avatar
1998 e420 ( 210 / 119 )
right on, thos link was enlightening, and useful, thanks for the help, mike
Old Oct 12, 2005 | 09:58 AM
E-Klasse's Avatar
W205 C300
The trim in the dash slide sideways and then pull out. You have to remove the speeker cover in the dash on the right side to get the large trim to move.
