What size tires for Brabus Rims 19x8.5 front and 19x9.5 rear, on 2002 E320 Sport?
Old Oct 27, 2005 | 03:36 AM
kangfu's Avatar
I recently purchased used Brabus rims, 19x8.5 front and 19x9.5 rear.
I need to know which size tires to purchase for a stock 2002 E320 sport.
How do I determine this information?
If anybody has any recommendations, please post.
Old Oct 27, 2005 | 05:30 AM
The Godfather's Avatar
4 wheeled car.
Run 245/35/19 on the front and 275/30/19 in the rear.
Old Oct 27, 2005 | 07:49 AM
Whitey's Avatar
98 W210 Advantgarde
Hmmmm, very agressive...I would go one size down on each.
Old Oct 27, 2005 | 02:15 PM
topdeez's Avatar
2012 E350 4matic/97 e320 and 01 ml320
no, no, no....Those are the perfect size tires to get for your car.... flaring fenders is not hard if you have too.
Old Oct 27, 2005 | 03:00 PM
Whitey's Avatar
98 W210 Advantgarde
Exactly my point and it also slows the car down and affects gas mileage...really depends on what he is after I guess.
Old Oct 27, 2005 | 04:23 PM
4 wheeled car.
That's the size most people run on such staggered setup. Like 235/35 and 265/30 gonna make such a difference lol.
Old Oct 27, 2005 | 05:03 PM
Hank's Avatar
that's 10mm. does it make a difference? why don't you ask iForge? LOL
Old Oct 27, 2005 | 08:25 PM
4 wheeled car.
5mm. duma!
Old Oct 27, 2005 | 11:14 PM
Mr. B's Avatar
'97 E320
hey… according to tirerack.com
that’s the recommended size tire for that size wheel…
here’s a tire calculator
use the calculator to see what happens to your speedometer reading when you change the size of your tires and wheels. the graphic shows your stock tire selection in an outline overlaid on your new tire selection. it will give you the entire dimension to compare between two sizes.
~ Mr. B ~
Old Oct 28, 2005 | 09:06 AM
Whitey's Avatar
98 W210 Advantgarde
~ Mr. B ~
.....And may I ask how much difference on the speedometer is one size down going to make it? 1.1% Are you going to be able to tell the difference on your analog speedometers? Not really.
However:
Is 10mm in width on the front tires going to make a difference in steering response? Definitely - try it on windy roads.
Is it going to rub? Possible, depending on how much he has lowered it and also bear in mind the inner control arm bolt problem that a lot of people have...that is on stock cars (do a search on E55Kev's posts and you will find it repeated numerous times).
Is 10mm on all four wheels i.e. 40mm of extra rubber in contact with the road, not to mention the extra unsprung weight that goes a long with that, going to affect pickup speed? Go figure.
For aftermarket application on stock W210s, AMG recommends 235's in the front and 265's widths in the rear on their 18"x8" and 18"x9" wheels. The same width will fit on 8.5 and 9.5" wheels comfortably. There is a difference...E55's have fenders rolled at the factory and stock W210 don't. The E55 also has a lot more power than an E320 to push those wider tires...I think it would be fair to say a lot of us would want to maintain the already limited level of performance (compared to the 55) on our cars - not slow the car down and use more gas...but of course, that is just my opinion.
Old Oct 28, 2005 | 04:23 PM
4 wheeled car.
Uhh... my stock 18s came w/ 245 and 275 combo.
Old Oct 29, 2005 | 03:38 AM
Whitey's Avatar
98 W210 Advantgarde
Yours is an E55 Mike. I said AMG AFTERMARKET application - check the AMG accessories book if you don't believe me.
Old Feb 22, 2021 | 12:00 PM
Luison's Avatar
C230 2007
Oficialmente las llantas para esos rines son: 19x8.5 29 235/35R19 19x9.5 35 265/30R19 Brabus
Old Feb 22, 2021 | 03:03 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Necropost...
This thread is 15 years old.
Old Feb 24, 2021 | 01:04 PM
raymond g-'s Avatar
99 E320
I don't understand the need to rebuke the new/delayed posting. They're merely offering an update/confirmation of information.
If it's not mis-information, leave it be. What's the harm?
