Pics of the latest mod (56k killer)
Seriously, looking good. Have you had a chance season them yet and feel the benefits? Since the front brakes do about 70% of the braking I have never put a big brake kit on my rears, just end up replacing with a stock sized, slotted/cross drilled brembo rotor and better pads, even in my track car. But with the e-class I will probably go with big brakes all around, just wondering if the performance gains are even noticable. Also what color are the hats, black??
Jose
jose
Brembo Grand Turismo Kits
MERCEDES E-Class Rear (W210) 1996 -> 2002
Kit Part Number: 2C1.6009A (drilled rotors)
crackhead
Thanks Benz.
The pic is of my rear drivers side brakes. I have stock W210 brakes with brembo drilled rotors. I am still confused. I see pics of the 03+ E55 with AMG brakes and the rotors are the same direction as mine hence I am still confused. Just to clarify my rotors should be the opposite direction as the AMG ones correct?
If you check Greg' thread of a similar setup, he has the rotors installed in the same direction as mine currently.
https://mbworld.org/forums/showthrea...hlight=drilled
Jose
Last edited by ArcticBenz; Feb 6, 2006 at 03:30 PM. Reason: attachments did not upload
I wonder what the braking feet is on the E55 compared to your brembo one, from 70 to zero.
What do u plan for your next mod?
https://mbworld.org/forums/showpost....98&postcount=7
I was told AMG rotors has not direction to reduce the cost.
I hope it help!
I hope it help!
Thanks for your help.
Here is the original thread that I had started when I got my brakes done.
https://mbworld.org/forums/e-class-w210/117095-brembo-drilled-axxis-ultimates-installed.html
