Fenders rolled!?! Rubbing with 18's??
I have a set of 18x8 and 18x9 amg mono 2's. I'd like to go with a H&R/Bilstein sport suspension setup. A few questions.
First off - 1999 E300 Turbodiesel
1. What size spring pads are appropriate? I have 235/40-18 and 265/35-18rears.
2. My big concern - I dont want to have any rubbing going on, will I , or how do I avoid it? I'd really like to avoid costly modifications as far as fender rolling etc, if at all possible.
Thanks,
Dave
Spring pads heights are different for each car. You have decide if you want lower. The stock pads may be fine because the H&R/Bilstein setup will lower all by themselves.
Chassis tuning is a step-by-step adventure. You add your wheels and upgrade your suspension and then test. If you have any rubbing then you 'have' to roll the fender lips.
Kev - Sounds good on the stock pads. What i'll do is figure out whats on there when they take the stock springs out, and go down from there. Maybe using the stock pads is cool in the E55. E55's are 3/4 in lower than a stock setup to start off with, so they probably come with closer to the correct pad size is my guess.
Anyone with a '96-'99 who has done this suspension mod, please speak up on your pad sizes. I think I may be the only one with an E300 thats been modified... 20 years from now someone will go, hey, that looks like that old E55(now in a junkyard) I had 20 years ago!:p
It doesn't sound like we have any forum members with E300's and wheels/susp.... Actually I think they only made like 1500 each year of 98 and 99, so thats likely. Its rare, but if I ever see one on the road, its always got some white hair in the drivers seat...
I asked which ones you had because I believe the fronts pads maybe/usually are bigger (more bumps) than the rear to compensate for the engine weight. Knowing the bumps you have can determine the ones you need to get.
Example: If 5 bumps in front and 4 in rear you would upgrade with:
4 front/3 rear
or
3 front/2 rear
or
2 front/1 rear
I don't think (only speculating) you could go 'even' all the way around if you started with uneven front and back.
There are only 4 pads sizes for the rear while 5 pad sizes for the front. So no 5 bump pads exist for the rear.
I think that Kev has the right idea. If you are really unsure, take an opportunity to look at what pads you are running as stock and this will give you an idea of how much of a change the drop will be. Rubbing shouldn't be a problem, it's just what type of look you want with the drop. The drop in suspension will change the camber to help the wheel clear the fender as well. Should look great.
Post pics.I am doing the same as well. Just installed 235/40/18 (f) and 265/35/18 (r). H&R and Bilstien Sports are on the way. I'm going #2 and 3 during the install. This is a drop of 1 bump from stock. The gap in my wheelwell is about 2 inches, so with a 1.4" drop with the H&R and another 3mm/bump with the pad I should have a 1/2" gap left. Perfect. I saw a CLK with the same set-up but with #1 and 2; it looked sweet but too low for my daily driver with the wheels tucked into the wheelwell. My only concern is that the wheel will still travel into the wheelwell as you drive over a bump and this may be too close to call without rolling at least the lip.
