BAS/ASR Fault Indicator light on
Please post me the diagnoses. Also my error is BAS/ASR not ESP.
Please DO a search for brake light switch there are threads that discussed this issue.
Yeah, U will have to remove the panel under the steering shaft, U can't see the switch without removing this piece...
I know your next question will be, How do U remove the panel? right???
Directions are in the threads too....
BTW, If you have messed with the brake light wires, then you might want to check the fuse....The fuse on my '96 is located on the left side of the dash next to the driver's side. If you've blown the fuse, U are likely to get the ABS/BAS error and no traction and NO brake lights... That's what happened to me.. I messed with the brake light cables and blew the fuse. I replaced the fuse and the error lights are gone...well I found this out, after I've changed the "brake light switch" and still getting the error.....
Thsi is a tempo fix. Brake switch is the colbret
My Dealer, MB of walton on Thames, Surrey, UK supplied me with Part No. MA001 545 01 09 Stoplight Switch which I popped in by removing the panel under the dash and replacing the old one.
Cured the problem.
Beware, there is also Part No. MA001 545 64 09 on facelifted models from about July 1999.
My proble was resolves for under £10!!
I had the same problem once, diagnosed as the switch by DAS but upon the suggestion of my mechanic, had my computer reset via DAS. Fixed the problem and never re-occured in the past 3 years.
i got a 1998 Mercedes E300TD and the BAS/ASR light keeps turning ON. In the center of the Dashboard, only the BAS is displayed. I have read on other forums that the brake light switch might be the problem or the voltage on the battery is low. That's not the case with my car. The BAS light only comes on when the outside temperature is below -1 degrees celsius and after a 5 minute drive. Even when it's extremely cold and i restart the car, the BAS light still comes on. I also noted that the engine's output performance is limited. When it's warm outside, the BAS never comes on. Please help me out guys.
