Hole in Engine
Old Mar 30, 2006 | 03:58 PM
shanmanz's Avatar
Angry Hole in Engine
The so called German Engineered MB E320 has a hole in Engine after just 5 yrs and 100k of use.
Here is the link to the full story
http://www.emergencemarketing.com/ar...e_study_on.php
Old Mar 30, 2006 | 04:21 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
There must be more to the story than whats here. This is quite unusual and for MB to turn their back or so he says on a problem like this when the car while out of warranty is still not that far out. I'd certainly like to see the service records and the like before I form an opinion. Takes a lot to put a hole in a block like severe overheat, running out of oil or lack of maintainence. Yes, its possible that there was a fault internally in the engine but the fact that MB does not want to do anything leads me to believe that there is lots more to this story. I have had 5 MB's since 1998 and all have been a good experience.
Old Mar 30, 2006 | 04:43 PM
shanmanz's Avatar
Have all the service records
Well I have all the service records did all the required maintanance. The dealer has all the records too.
Old Mar 30, 2006 | 05:04 PM
Chappy's Avatar
AMG
Is the E for sale? What are you asking?
Old Mar 30, 2006 | 09:32 PM
cragigotgame's Avatar
97 E420 90 300E
Another good example of why to do your own maintenence.
I have a 97 E420 with 170k and havent spent more that $1500 in the five years Ive owned it. Maybe you just had a bad apple.
Old Mar 31, 2006 | 03:50 AM
humbley's Avatar
In my experience 35 years in the motor trade these problems are owner created ignoring warning lights in the hope that nothing is wrong is the usual cause, mechanical ignorance,have seen it many times,an audi 100 many years ago the owner ran it out of oil, ignored the oil light, and just drove it until it seized solid, total supidity !. An engine thats done 100000 mile does not just throw a rod for no reason,this is usualy caused by lack of oil to the bearing shell this then destroys itself and the big end cap hammers on the crank pin stretches the bolts the bolts loosen and hay presto the cap comes of and the rod goes through the side of the block, seen it loads a times. Always take note of any oil problems,soon as that light comes on stop ! !
Old Mar 31, 2006 | 02:53 PM
OceanView's Avatar
W212 & W210
$14K for a new engine?
That's crazy
Old Mar 31, 2006 | 03:02 PM
Ala-benz's Avatar
'00 E430, '83 Porsche 928S
What is the point for the post on this forum? Most people use this forum to learn more about the car they have chosen to own. It sounds like you do not know anything about your car and you habitually dole out the cash to make someone else fix it. Go back an rant on the other forum unless you have some useful information for the rest of us.
Old Mar 31, 2006 | 05:50 PM
sosh's Avatar
That's crazy
Actually thats not a bad price. Aluminum engines are expensive and that may include labor. His is not rebuildable or even exchangeable for a rebuilt or reman engine due to the hole in the block. I also believe that this guy does not have a clue as it must have overheated or been run low on oil. He also must have had some sort of warning like a CEL, MFD warning or even some unusual noise before it blew but he kept right on motoring. Like they say it will run without oil but not for long and never again.
Old Mar 31, 2006 | 06:15 PM
SL BRABUS's Avatar
2 SL with every Brabus mods available & Class A competition sound system
you know by using this will cause a hole in your engine....... ..
