Early W210 Blower Motor Regulator Replacement DIY Here...
Old Aug 25, 2010 | 01:46 PM
  #151
tdlaw91's Avatar
1999 E430 Mercedes
Does anyone have pictures of the new style wiring to the old style regulator? year 1999 E430 BLOWER REGULATOR
Old Aug 25, 2010 | 08:29 PM
  #152
bng1959's Avatar
2017 S550 A217,2006 SL500,2002 CLK430
For those who have a weak A/C blower that does not seem to change speed despite where you set the controls, here is a DIY to replace your Blower Motor Regulator.
At some point in the run of the W210, Mercedes-Benz decided to redesign the unreliable regulator. Unfortunately, the redesign included the entire blower assembly, so if you try to buy a replacement for the regulator from your dealer you will be sold a new blower assembly, a new housing, and the new regulator.
However, a former local wrench in the Atlanta area described adapting the blower motor regulator from a W140 (S-Class) to the early W210 (The later W210 has a totally redesigned part and only a new regulator is required if your part fails). Here is my interpretation of the adaptation:
First of all lets see where the part is located. Look under the passenger side footwell and look up. This is what you will see:
http://www.bimmerboard.com/members/i...l/IMG_0900.JPG
Remove two phillips head screws and the cover can be pulled off toward the seat. With that cover off you will see the blower motor cover:
http://www.bimmerboard.com/members/i...l/IMG_0871.JPG
Remove the five Torx screws(T-20 i believe) and you will expose the blower motor and harness near the corner to your right nearest you:
http://www.bimmerboard.com/members/i...l/IMG_0895.JPG
Disconnect the harness by pulling apart. There was no locking mechanism that I could find. After releasing the harness, remove four torx screws(Same size as the cover) and the blower assembly will drop down. If you look up the void left by dropping the blower you will see your A/C filters. Check their condition and replace them if they look dirty at all. I had replaced mine recently and they still looked new:
http://www.bimmerboard.com/members/i...l/IMG_0891.JPG
Take you blower assembly to your work table and you will see the blower motor regulator attached to the blower motor with two torx screws of the same size as all the others you removed earlier. Here is a picture of the old and new regulators. I purchased mine from
http://www.autohausaz.com/
http://www.bimmerboard.com/members/i...l/IMG_0874.JPG
Remove the two torx screws and cut your OLD harness right next to the OLD regulator. You will be cutting four wires: a thick black one, a thick blue one, and two thinner yellow and red ones:
http://www.bimmerboard.com/members/i...l/IMG_0881.JPG
I stripped most of the black sheath covering the three wires on the OLD harness to give myself room to strip the insulation off of the three wires I will need to splice.
Next take your new harness and regulator. You can go ahead and connect the blue wire with the spade connector to the blower motor. You will need to remove the blue wire coming from the OLD harness from the motor to do this. Throw the old blue wire away. The OLD red wire attached to the blower motor will stay. This is what it will look like:
http://www.bimmerboard.com/members/i...l/IMG_0883.JPG
Now cut the four wires going into the NEW harness connector(Cut the wires as far away from the new regulator as possible). Note that the blue one goes straight to the blower motor so it will not be cut. You will need to cut right next to the connector box in order to leave enough wire to splice to the OLD harness. When you cut the four wires, you can discard the thick red wire. The other three wires will be spliced to the three wires (black,yellow and red) from the OLD harness. Here's how i spliced and soddered mine:
http://www.bimmerboard.com/members/i...l/IMG_0886.JPG
I then taped each wire with electrical tape, put a very thin coat of the included dielectric grease to the new regulator, and mounted the new regulator with the two new torx screws supplied with the new harness:
http://www.bimmerboard.com/members/i...l/IMG_0888.JPG
I then installed it under the dash in reverse order and started the car up. Woo hoo! It worked. Lots of $$$ saved.
Old Sep 3, 2010 | 12:55 AM
  #153
MAILCNX's Avatar
1997 e-320
Arrow BLOWER REGULATOR VOLTAGE MEASUREMENT
Originally Posted by Mr. B
Excellent DIY write-up…
thought about doing one myself after all the research i’ve done on this fix… i didn’t really find a detailed "how-to" with pictures (although a couple of members claimed they would do one)… so i had plans to do it when my part arrives… now i won’t have too…
i tore my regulator out last week to test it and discovered it’s only putting out 3.2 volts… working spec should be at 0.8 volts low to 6.0 volts high… and you can’t fix the regulator… do to it being a “potted” module (sealed components)… the only fix is to replace the thing and your instructions do the job…
like you… i searched the web and found autohausaz.com to be the lowest priced supplier (and i must say excellent service) with two manufacturers: Kaehler (KAE) #1408218351 at $163.63 and Behr # 1408218451 at $214.79...
i ordered the more expensive unit by Behr (Germany) because i was told the less expensive version from KAE is made in France and does not hold up as well… although… i do believe they may have since modified the heat sink from the original version (notice it’s thicker) and even they’re model works better then what was originally used in the E-class… (which i believe they supplied as well).
anyhow… great job… this fix should be of use to a lot of people… since it’s a common problem…
my boss noticed what i was doing and asked if i would check his ‘97 E320... and i found it to be weak as well… it’s the same as mine… only 3 volts… blowing at half speed even though the controller say's max... looks like i’ll be doing two conversions.
thanks again,
~ Mr. B ~
I seem to have the same problem; not enough air even when the climate controlunit stays at full speed. I am going to do the W140 regulator change this week. I would like to do the voltage test you did. Could you please explain in detail how you checked the voltage reaching the motor at diffrent speed control settings. That would be very interesting test and and it nails the porblem.
Thanks.
Joe.
Old Sep 12, 2010 | 02:16 PM
  #154
skipsantos's Avatar
2008 E350 Sport/2016 E350
Anyone use Importec?
http://www.importecwarehouse.com/Mer...1408218351.htm
Old Sep 16, 2010 | 05:31 PM
  #155
samwell_1's Avatar
1999 e300 td
importec has a much cheaper s class w140 regulator
Thank-you very much for taking the time to inform us of this work-around. it saved me a bundle of money and works great. too bad the dealers don't tell us about this!!!
Old Sep 27, 2010 | 12:52 AM
  #156
MAILCNX's Avatar
1997 e-320
YOUR SOLUTION FOR THE BLOWER REGULATOR WAS SIMPLY AMAZINGLY EASY AND PERFECT FOR ME. IT APPEARS COMPLICATED WHEN YOU READ ALL THE STEPS BUT WHEN YOU GET TO DO IT ONE BY ONE IT IS SO SIMPLE. MINE IS WORKING PERFECT IS I GOT THE AIR FLOW I NEVER HAD.
ANY ONE CAN DO IT WITH KNOWLEDGE OF SOLDERING. SO ANY ONE WAITING TO DO THIS MOD, PLEASE GO AHEAD, IT IS SIMPLER THAN IT LOOKS.
THANKS TONY ONECE AGAIN.
Old Oct 2, 2010 | 02:59 PM
  #157
batman54's Avatar
'97 E320 '97 AMG C280
I've had the regulator proble for a while. I think it progressively got worse, if that's possible.
I could live with it over the summer, but being in Canada, I figured I better fix it before winter, or I could be scraping my windows on the inside the way I did with an old VW Beetle about 35 years ago!
Anyway, after reading the thread, I was convinced this was the problem I was experiencing.
I called my local dealer and even the S Class regulator (part only) was going to be about $600. I didn't even bother asking what the E class regulator/blower combo would be but I assume in the $1000 - $1200 range. I'd love to know.
So, I ordered the S class regulator from the Arizona company listed in some of the forum messages.
It currently cost $237 and being I'm in Canada I got hit for about $30 in taxes in Canada as well.
I don't consider myself particularly handy, but I followed the instructions to a T and "voila"!!! it worked like a champ.
It probably took me a total of 1 - 1 1/2 hours and I probably saved $1000 or more compared to the parts and labour if I took it in to the dealer.
Not only that... I am a HERO to my wife, and am feeling very accomplished.
Thanks to MB World, and the BNG1959 for MAKING MY WEEKEND!
Old Oct 13, 2010 | 02:48 PM
  #158
podski's Avatar
2001 E320 4MATIC
Does 2001 E320 have the updated blower/regulator?
I am considering purchasing a 2001 E320 4MATIC. On the test drive I noticed that in "AUTO" mode, the speed of the blower motor kept fluctuating noticeably. I assume that it needs to have the regulator replaced as discussed in this thread, though I didn't see much discussion on fluctuating blower speeds; only poor blower speed in AUTO setting.
Can anyone tell me if this model is considered a later W210 that would have the updated blower/regulator assembly.
A quick google search seems to show me that I can get either the S Class or E class regulator for under $75. Does that seem right? Many posts in this thread discuss the price of replacement regulators at more than $150 or even more than $200, but they are very old posts.
Any advice will be greatly appreciated.
Thanks,
Ken
Old Oct 17, 2010 | 03:21 PM
  #159
Hikingmapa's Avatar
1998 E300 TD
Blower working again
Have to say thank you for Tony again. He posted the original fix back in 2001! Hope he comes back to this forum from time to time.
I bought the regulator from Importec for $80.-. The connector is actually the same so I plugged it in to make sure the part works prior to finalize the cable switching portion. Te blower is working again .
Old Nov 1, 2010 | 06:16 PM
  #160
Brian McL's Avatar
Worked great. Bought the part from FCP Groton. $50.99. 1 year warranty. Sent to Canada no problems. I would use a connector on the large black wire....to hard to solder. Hard to get enough heat into it and I'm using a 140 watt soldering iron. The other 2 are easy. Use heat shrink if you can on all three. Remember to put it on BEFORE you solder the wires together.
Old Dec 7, 2010 | 03:31 PM
  #161
chivijash's Avatar
e320
Hi Tony, great post.
I have a weak A/C blower situation too. But it change the speed when I set the controls, today i changed the cabin filters ( they were really dirty ) and it blows better , but just a little bit . should I change Blower Motor Regulator only, or maybe is the whole Blower Motor weak?
Old Dec 23, 2010 | 06:49 AM
  #162
fromcgee's Avatar
e320
heat
I also have a 99 e320 with no heat, i order the replacement regulator and modified as the instructions show, everything looked great!! reinstalled it back in the car and turned it on the test and it worked but only for about 15 min then it went out.
the part i purchased was on of off brands on ebay, i connected a power source to the motor and it turns. so i checked all my connections again but still it will not work when connected in the car. also nothing look burnt or damaged in any way not even the plastic clips. I think it may just be a bad ebay part but i saw several post on there where people had success with using them.
is there anything else i can check or do before ordering another regulator
Old Jan 8, 2011 | 02:28 AM
  #163
aslkick's Avatar
E320
Take you blower assembly to your work table and you will see the blower motor regulator attached to the blower motor with two torx screws of the same size as all the others you removed earlier. Here is a picture of the old and new regulators. I purchased mine from http://www.autohausaz.com/
hi i did what you said and dont work
Old Jan 8, 2011 | 02:47 AM
  #164
aslkick's Avatar
E320
it will work if replace with after market unit?
Old Jan 11, 2011 | 06:34 PM
  #165
havanajoe26's Avatar
2008 BMW 750LI, 1997 MBZ E320
Another Successful Application 1997 E320
Thanks to this great forum, I was able to fix it in less than 30 min once I had the part in hand. The beauty was in the part itself. I was a little hesitant to cut the wires and splice, but was going to do it anyway.
I was able to find a Bosch part sold by bmaparts.com. It came with two sets of cables. A short for the original S model application and a long version that fit my 1997 E320 perfect. Looks like they figured out what people were doing! Here is the part number on their website #BSH028373. Got it for $109 ($120 w/tax in CA), and BOSCH!
The pictures on the website do not show both sets of cables, I found out upon opening the box. I should have taken pics to post on here.
So no need to cut, all plug n play!
Old Feb 12, 2011 | 02:57 PM
  #166
cmovic's Avatar
1999 E320 Wagon 4matic
One more happy MB. Saved $800 over the dealer quoted repair on my kids' car. Thanks!
Old Feb 19, 2011 | 10:20 AM
  #167
Cracker Red's Avatar
535i
FYI, I ordered from BMA autoparts as well, got the box labeled bosch, with the extra harness.
Worked for 2 weeks, then caput. Now BMA wants to charge me $15 for a "return fee" to take back the defective part.
Old Feb 21, 2011 | 03:56 PM
  #168
Wess's Avatar
2000 E 430
I took my 00 e430 out the other day after having it stored most of the winter. I put the the climate control on auto, 75 degrees. It was around 40 outside. I noticed that after the interior had warmed up, the blower fan was pulsating, the indicator on the climate control read 3 bars. Do you think the regulator is going or something else. I can put the fan on manual high or defrost and it works strongly. Thanks for any inputs.
Old Feb 28, 2011 | 06:01 PM
  #169
skipsantos's Avatar
Blower Regulator Replacement
Thanks to Tony for the DIY. It certainly took more than 30 minutes from start to finish, but not by terribly much. I also changed the cabin filters and charcoal filters while I was doing this. Cost for W140 regulator was $69.95from Importec.
Old Apr 2, 2011 | 01:34 PM
  #170
yahara's Avatar
1967 250sl, 1998 E320
Blower VR now Alternator VR?
Thanks to this thread I performed the w140 to w210 A/C voltage regulator transplant and I have working climate control in my 98 E320 again!
However, the next day, I got a battery warning light. Diagnostics indeed show voltage at around 11.5 at idle. The car does have over 230k and is probably running the original alternator. Battery is less than a year old. So it is quite likely that I need to put in a reman alternator or at least a new VR and brushes into the existing alternator.
But I am suspicious of the timing. Could I have done something during my blower regulator repair to cause the low voltage readings triggering my battery warning light? Too much heat during soldering?
Thanks for anyone's input.
Old Apr 6, 2011 | 01:52 PM
  #171
JohnnyRock's Avatar
1998 C43 AMG
Hi guys, Benz noobie here with a '98 C43 AMG and this problem. Can anyone confirm if the fix/location of the regulator is the same for my car (W202)?
Old Apr 15, 2011 | 12:55 PM
  #172
noshopclass's Avatar
'97 E300 & '89 190 D
Thanks HavanaJoe26, and all posters!
The dealer quoted $900. to replace the blower regulator ('97 E 300) two days ago. Checked the forums...ordered the replacement regulator for the "S" from mbaparts.com,
and all seems to be working fine. I can't thank you all enough!
Old May 30, 2011 | 10:29 AM
  #173
560 SEC's Avatar
2011 S550
A/C fan not working
I have a 2002 E430 Sport. For awhile the fan would race up and down, now it works when it wants to and can't regulate the fan speed. When it comes on it's high speed only.
The unit was charged a few months ago. Is it the fan regulator ? Can you buy just the regulator or do I need to use Tony's fix?
Old May 30, 2011 | 10:58 AM
  #174
Brian McL's Avatar
Regulator
It's the regulator. Pretty easy to replace.
On that year they aren't that expensive.
The re-wiring for the earlier regulators doesn't apply to yours.
Old May 30, 2011 | 11:23 AM
  #175
560 SEC's Avatar
2011 S550
Thank you
You have already rated this thread Rating: Thread Rating: 14 votes, 5.00 average.
