Jacking up the car
The stock jack seems a bit wimpy.
worm gear side jacks. it gives me many more lifting options, is more secure,
lower center of gravity, quicker lifting and lowering. hydraulic floor jack is
50x heavier.
Same question I was going to ask. I'm always afraid I'll crush something underneath.
Also, what is the correct torque for the lug nuts? I've heard both 40lbs and 80lbs, depending on the mechanic I asked.
Never been to Pep Boys before. Nearby the tool section was the 'spinner' wheel section. I was so tempted.
this is my setup, the jack is a rapid pump 1.5ton aluminum w/ 3-1/4" clearance for my S2000, and i have 4 Craftsman 3-ton jack stands (for 24000lb of support - gives me piece of mind when I get under the cars I work on)
Secondly, if you have a very tall garage in your home, you might want to consider just buying a "car lift". Very convenient. Plus, it'll double your parking space.
Seriously, that's a good question.
The only thing I can think of, and what I have been doing, is to lift the car with the factory jack and use the mentioned points for the jack stands.
Until I get an answer to the question, that is how it will be done!
What I like to do when swapping out my wheels, is clean (scrub) the backside of the rims so that I keep the brake dust buildup to a minimum.
Of course, the car is lifted on jack stands all this time while I finish polishing the wheels so I am in no rush. Also, I get the chance to peek around underneath the car for any preventative maintenence issues.
Don't be afraid,just put them on at 3 am,drive around til 4,and at 4:30 .put your other rims back on. We'll never know the difference.....
Yes, this should have been posted in the correct forum section
, thanks for the reminder (and greetings)...
