Which Fuse is for the Radio??
can also check your fuse map.
this is from 99 MY
were you able to find a fuse map for your year/model while you were
underneath the hood? i was curious how differnent they were from
my 99 E320. also, on the far left end of your dash....< inch from the
door panel, should be another fuse box as well as map. that one
is another subpanel
hairline fractures so it is always better to test the continuity using a volt meter or battery
and light bulb. the radio is also likely to have a fuse on the rear panel. since you have
a new radio, we're not going to know which model you have, right? so better to include
the technical description and specs as well
