Old Jun 4, 2015, 08:06 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior
Print Wikipost
How do you remove the wood trim pieces?
Old Mar 30, 2007 | 06:54 AM
The Godfather's Avatar
4 wheeled car.
Im trying to remove every single wood pieces..how to do it?
Old Mar 30, 2007 | 06:59 AM
kevins e55's Avatar
the trip on top that goes over the glove box is just held in by u nuts and long metal studs so you can pull that out as for the wood trim by the stereo you have to undo 2 screws above the ash tray some what hidden away but easy to get to you should remove the headunit and heater with the mercedes keys to get to it if you take it to a stereo shop theyll charge you 5 bucks to do it. By the shifter all the just pops out go by the cupholder and get a hook and pull up by the bottom its easy
Old Mar 30, 2007 | 08:21 AM
elchuang's Avatar
W210, VW Phaeton
hmm, sure sounds like you're up to no good again
Old Mar 30, 2007 | 08:23 AM
4 wheeled car.
I know how to take out the center console ones but I dont know about the doors.... and for the long piece above the glove box, I dont get it...
4 wheeled car.
hehehehehe
Old Mar 30, 2007 | 09:39 AM
raymond g-'s Avatar
99 E320
http://w210.pietrzyk.net/Default.htm
dash wood trim should be included in video here. dont remember if the door
trim is shown.
Old Mar 30, 2007 | 10:29 AM
kevins e55's Avatar
im not even sure you can take the wood trim from the door
Old Mar 30, 2007 | 11:32 AM
raymond g-'s Avatar
99 E320
running off to work now, but just viewed the door panel removal and in the
video, you see couple of cheap metal, one way fasteners right about where
the door wood trim is located. looks hopeful....but then again, i'm continually
surprised that MB can design a "you'll-need-to-replace-the-whole-thing" some-
thing.
Old Mar 30, 2007 | 12:35 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The Door panels MUST Be removed to take the wood trim off.....
Dash Is Simple...
Old Mar 30, 2007 | 01:37 PM
E-Klasse's Avatar
W205 C300
http://w210.pietrzyk.net/disassembly_68inter_step3.htm
The wood trim on the dash slides over to the right a few inches and then pull off. You have to lift the speaker cover on the right side and pull the trim back first.
Old Mar 30, 2007 | 02:56 PM
4 wheeled car.
ah ok cool. What about the left side of the dash wood piece?
Old Mar 30, 2007 | 06:39 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Same thing as the right. I was able to stick my finger in between the cluster and the left wood piece and pulled it right off. Be gentle...
Old Mar 30, 2007 | 08:08 PM
Tommy_s4's Avatar
ML320, Looking for my S4
thanks to this thread, i now know how take off my wood trims to wrap them in carbon fiber.
