E430 Limited To 130??
Old Oct 17, 2002 | 10:10 PM
Stinger's Avatar
2000 E430 Bordeaux Red
Question E430 Limited To 130??
I had my E430 out on the interstate today and hit the limiter at 130 mph. It feels very strong up to that point and i am sure it can do more. How do you get around the limiter and how much?? I have the 17" sport rims with ZR rated tires so i am not tire speed limited.
Old Oct 18, 2002 | 04:20 AM
Dema's Avatar
i535
You should be able to hit 156mph accordingly the manual.
Old Oct 18, 2002 | 10:26 AM
6.3's Avatar
6.3
2003 s500 sport
My manual says 130mph
page 20 of my 98 e430 manual talks about the factory equiped tires being H rated up to 130 mph and quote:
"Models E320 and E430:
An electronic speed limiter prevents your vehicle from exceeding the speed rating".
Old Oct 18, 2002 | 06:38 PM
Stinger's Avatar
I have ZR rated (180+mph) so it can handle it now. But how do i get around the pesky limiter? and do any other limiters lurk behind the other?
Old Oct 18, 2002 | 07:36 PM
Dema's Avatar
i535
Re: My manual says 130mph
It looks like the manual changed after. If you are interested I can attach a photo with the page from my manual.
Old Oct 19, 2002 | 02:32 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
there is more than 1 limiter on the vehicle.... you have the speed limiter, rev limiter, and others.... you can call renntech and they can probably list you a few....
i've heard somewhere that if you change out the speedo/console.... to maybe an E55, one of the limiters might be moved up to that of the E55. not sure though.
Old Oct 21, 2002 | 01:12 PM
AJChenMPH's Avatar
2008 Subaru Legacy GT Limited
BTW, Z-rated tires are only "149+ MPH". Y-rated tires are true 180+ MPH tires.
http://www.tirerack.com/tires/tirete...eral/speed.htm
As far as having speed governors removed...I have a governor on my 2000 VW Passat, the only way to get around it was to have the ECU chip replaced. Since then, I haven't taken a v-max run (NYC streets are not conducive to high-speed driving :p ), but I'm reasonably sure that I could take it past 130 mph now.
Old Oct 26, 2002 | 02:47 AM
Dema's Avatar
i535
Ok, there is promised photocopy of W210 manual:
Old Oct 26, 2002 | 09:33 AM
pocholin's Avatar
Volvo V90 CC
WOW, how do you get this?
E430 is supplied with W rated tires (168 mph)
E55 is supplied with Z rated tires (149 mph)
There is something wrong with MB, isn't it?
Old Oct 27, 2002 | 01:25 AM
Dema's Avatar
i535
E55 tires are bigger, so it can be a clue.
Old Oct 27, 2002 | 09:57 PM
livetodrive's Avatar
2001 E-430 4-Matic
My 2001 E 430 4-Matic also came with ZR-rated tires. The manuals, however, states "Your vehicle is factory equipped with "H"-rated tires, which have a speed rating of 130 mph. An electronic speed limiter for models E 320 and E 430 prevents your vehicle from exceeding the speed rating."
Unlike Joe Walsh, I don't have a limo, so I haven't tested the speed limiter.
"My Maserati does 185, I lost my license, now I don't drive."
Old Oct 28, 2002 | 04:34 PM
Air Marshall Eldritch's Avatar
John Deere
Perhaps the manual is just written for the lowest common denominator, i.e. the capability of the E320. The 430 Sport gets Z-rated tires, though I don't know about the non-sport model.
