brake pads
Can you guys advise if it's true that discs ALWAYS have to be replaced each time on these 2000+ MBs, vs. getting the rotors resurfaced and just getting new pads?
The common "reason" cited is that Mercedes uses soft steel for their rotors. That notion makes no sense at all. If that were the case, these things would just bend. Are people suggesting that rotor and steel technology is worse than decades previously?
Minimum thickness specs are clearly stated and are even stamped on the edge of the rotors. As long as turning them won't take the rotors below spec, it's perfectly fine.
Incidentally, I've replaced my pads rather infrequently. The aftermarket Porterfield pads have lasted a scary amount of time with no ill effects on the rotors.
thx.
www.autohausaz.com
The suggestion about the economics of replacing them has some merit except for those who have already replaced them with high end aftermarket rotors. In any case, I don't see the point of tossing perfectly good rotors if all that's needed is a surface reconditioning.
I believe that you have the Green stuff pads, they are kind to the rotors and the wheels stay clean
It's really not a safety issue, so take the risk, if you desire. The worse thing that can happen is buying another set of pads, so no biggie ($75).
Check: http://www.thebenzbin.com/ for parts also.
David
David
i'm thinking about just sticking on new pads and seeing if rotors are ok, but what's the deal w/ dust filter(or is that not related to brake job)? This lasted 33k miles and 2 yrs of surface street driving.
in summary, on my prior brake job, the mechanic charged me $750 for:
sensor $13 for 2
dust filter $27.50
PAD front, $78
Brake set, rear $80
part cleaner, $10 for two
...$270 for front/rear rotors
...and 4 hrs of labor.
p.s. haven't checked yet, but it could just be the fronts that need replacing - display just says pads and doesn't say front or rear.
Aren't the brakes composites and not "turnable?" In any case, if they're not out of spec and not out of round, there's no need to replace the rotors. Just slap the new pads and you'll be good to go.
ATE rotors aren't that expensive...check around. Brake service is really straightforward on these cars.
I have had all rotors replaced and brakes and never paid nearly that much! I don't remember the exact price I paid I will have to look for the receipt....but if I'm not mistaken the rotors are like $80 bucks or less for 2....and my indie orders all my parts from mercedes.
My indie said that they replace the rotors if they are too low...but they can be resurfaced...
also because the parts-rotors,pads,sensors are not as expensive compared to other makes, they may sometimes replace them all......go figure....but the last time I had them done they resurfaced the rotors, changed pads in sensor etc....when I used to have a Acura Legend I think the rotors were like 180 or so, and my brake jobs were much more expensive than with the benz.
If you have a led foot, and do a lot of stop and go...you will run through brakes quicker!
sensor $13 for 2
dust filter $27.50
PAD front, $78
Brake set, rear $80
how much should he charge for labor for putting on new pads?
p.s. the good news on my e320 cabriolet that had the brake lights on/off was apparently wiring harness. he's charging me $50 for 1 yr labor to fix...but i'm ok w/ that.
i was just quoting a previous post where someone used that word.
yes, we will definitely be checking the thickness.
it's interesing w/ our 95 E320 cabriolet, i examined the history for its entire 78k miles of service ad MB dealers, and even there they got about 3 sets of pads before replacing rotors. my gut feel is that MB might have changed their protocol because i also can't understand how the discs got weaker and wear faster when they changed the chasis for E class.
dropping the car off this am so will know soon enough.
thx everyone for input that MBs do not always need new discs every single time of installing new pads.
p.s. on the other hand, my BMW guy saying that it always goes in pairs and that each time the discs are always below minimum thickness, thus new discs required.
