200 E430 Sport Check Engine Light
Old Sep 21, 2007 | 11:01 AM
jpowell's Avatar
1983-300CD Turbo D 77k miles, 1985 300TD 300k+ miles, 2000 e430 sport 95K miles
I have an 2000 E430 Sport with the check engine light on. The results from the emission test are:
P0170 Fuel Trim Malfunction Bank 1
P0173 Fuel Trim Malfunction Bank 1
what should i do to correct this-most research has show that its the air flow mass-is this correct-if so how can i determine?
Old Sep 21, 2007 | 11:16 AM
Air Marshall Eldritch's Avatar
John Deere
O a search for the hundreds of MAF replacement discussions here. Find the mentioned insert online, and try it (or first try the cleaner for an even cheaper test).
In all likelihood, that will solve your problem. CEL will reset itself in 45 minutes of drive time.
Old Sep 21, 2007 | 11:21 AM
MBSL600's Avatar
SL600
PO170 is Fuel Trim Bank 1 but PO173 is Fuel Trim Bank 2. I had PO170 this week and put a new MAF on bank one and that code went away but have more to do. Hope that helps. dpowell
Old Sep 21, 2007 | 11:22 AM
jpowell's Avatar
do you mean clean the mass air flow sensor first?
Old Sep 21, 2007 | 11:23 AM
jpowell's Avatar
was your chk engine light on? did it go away?
Old Sep 21, 2007 | 11:29 AM
MBSL600's Avatar
SL600
No but I have other problems I am working on but the PO170 did go away. CRC makes the cleaner and it did work on one but not the other so I had to replace it.
Old Sep 21, 2007 | 12:58 PM
ohlord's Avatar
Maf
we only have one maf on the E,you have two on the 600sl???Bank 1 and bank 2 are both fed the maf adjusted fuel data from the same air box.
DIY clean or r/r over on benzworld.org w210 forum in the diy section.It is the problem,running any air filter other then oem?replace the filter when you clean or replace the maf.
autohausaz.com germanstar.net,code will clear,sometimes the light will come back on,clear it again while the engine adapts to the new fuel curve.
ohlord
"GOT CODES?"
Your 2000 is getting ready for plugs $2.79 each at schucks/kraggen/autozone and a very good diy over on benzworld also
The maf insert which is the part that gets worn out,burned out,dirted out,is avail from germanstar.net for $129 http://www.germanstar.net/MAF.htm easy r/r and way less then a whole new maf.
