No Throttle Responce...
Here's what i found:
"The new type Mercedes Bosch throttle bodies are starting to fail. Common problems will be
rough idling, lack of power and/or driving problems with different pedal positions (due to faulty
TPS). Cruise control can often fail to operate.
Fitted to Mercedes cars '98 onwards C / E / CLK / SLK Class."
Ive had a bad MAF but instead of the RPMs being slow they would bobble if you pegged it because i guess the ECU wasnt getting any information.
rats like the coating.So when A new sensor is installed always check the wires for proper plug in and frayed or worn fittings and wire condition.Did I not point that out in another post dealing with this issue?This is the time of year you often find rat droppings on top of the engine under the engine cover if you pop it off to inspect.Have some solace though rats and mice love BMW wire harnesses even more,so park one in your driveway as a trap like I do
ohlord"Looks like it is unplugged or faulty.Check all wires to it"
post #13 from https://mbworld.org/forums/e-class-w210/220379-accelerator-issues-check-engine-light-please-help.html
damn rats
