I'm stuck
Old Jan 31, 2008 | 03:08 PM
Air Marshall Eldritch's Avatar
John Deere
I'm stuck
There is a little spring inside the side-view mirror that pulls the housing back into place if you bend it backward, I suppose to give the mirror unit some play if you accidentally bump into a pole or some such.
Trouble is, the metal spring connects to the base of the unit by a small connection that has broken on my passenger side. So the housing will sit properly but only if it isnt touched. (stable, but loose)
Unfortunately, my state inspection now includes wiggling all mirrors and light assemblies to make sure they are secure, and I failed because of this.
My parts guy can sometimes find a used (and very rare) replacement housing for over $400, new is $800.
Has anyone encountered this sort of problem? I certainly don't want to spend that kind of money on this.
Old Jan 31, 2008 | 03:22 PM
raymond g-'s Avatar
99 E320
1 - pull off mirror cover. zip tie into place. you can opt to cut it slightly so
that it'll be a designed fracture point should hard impact occur to the mirror.
reinstall mirror cover. 1¢
2 - remove mirror housing/frame from door. have friend weld, or JBWeld....
then redrill mirror spring anchor hole. $10 for JBWeld, time, beer, or dinner
3 - replace mirror frame/assembly. $4-500
ps...i hear of this breakage occasionally. a weak design.
Old Jan 31, 2008 | 03:25 PM
John Deere
Raymond to the rescue!
Stupid question...how do I pull off the cover?
By the way, look at this:
http://www2.partstrain.com/store/?N=...271+11921+9162
Big price swing between brands.
Old Jan 31, 2008 | 04:17 PM
ohlord's Avatar
Try
http://w210.pietrzyk.net/disassembly_88hoodfend.htm
ohlord
Old Jan 31, 2008 | 04:20 PM
John Deere
Originally Posted by ohlord
The video doesn't play for me. Does it work for you?
Old Jan 31, 2008 | 04:37 PM
ohlord's Avatar
Yes
in firefox,what browser are you using?Sometimes it takes a few seconds and no need to hit play.
ohlord
raymond also posted this one to you tube google w210 mirror you tube see if it is out there
Old Jan 31, 2008 | 05:06 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I encountered same problem and was able to install 1/4 20 X 3/8 pan head machine screw and nut in the location of the orginal spring purchase on the frame. so far so good.
On the left you see a vertical wire clip this holds the cover on,
Slide cover off
You can see the spring broken loose and the slot to the right that I used to bolt it back together.
Old Jan 31, 2008 | 07:13 PM
raymond g-'s Avatar
99 E320
i'm getting the video to play...both IE and Netscape. hmm...okay, try this one
http://www.youtube.com/watch?v=Qn0bgoME_mQ
Old Feb 4, 2008 | 03:27 PM
John Deere
I tried the zip ties, but it's really difficult to find a solid spot to wrap them around. With two ties on, the back and forth movement was somewhat solid, but the up and down travel was still floppy. I don't know what standard is used by the inspection monkeys.
So I picked up some JB Weld. It is cold here, so the first attempt took over 18 hours to dry, and then snapped right off anyway (the contact points are just too small. Now I'm waiting on a second (larger) application to dry.
Old Feb 22, 2008 | 03:12 PM
John Deere
Epilogue:
I spent a whole week building up the JBweld connection point layer by layer. Luckily we had a freak warm day up to 70 degrees (in Feb!) that allowed the mess to cure more properly. Turns out both ends of the spring perches had failed. So now with the weld, the housing does not move at all, although I didn't really load test it before re-inspection.
When all was said and done, the re-inspector glanced over from the other side of the car, and he passed me.
What I noticed is that the tension of that spring is very, very heavy. I'm surprised more people don't have this problem.
Old Feb 22, 2008 | 03:18 PM
Glad it made it through the inspection. Next time mine breaks I may try a bungee cord, that spring is too much!
Old Feb 22, 2008 | 03:48 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
WTF...........where do you get your car inspected ?
Old Feb 22, 2008 | 03:53 PM
John Deere
At the DMV at Quakerbridge. As I was sitting next in line waiting the first time, I watched the guy walk around the car in front of me banging on all the tail lights with his fist. My first thought was "Hey, you're going to break something dummy"
Old Feb 22, 2008 | 03:57 PM
C43AMG's Avatar
Veteran: Army
I would have gotten his supervisor and asked to see the inspection criteria for "loose mirrors and tail lights".What did the failed inspection report say?
Old Feb 22, 2008 | 04:01 PM
John Deere
Once you get the red sticker of shame, they won't listen. The printed report stated "Passenger mirror not secure".
Nicely ambiguous, isn't it?
Wasn't it once even normal for cars not to even have a passenger side mirror?
Old Feb 22, 2008 | 04:05 PM
C43AMG's Avatar
Veteran: Army
Yes , you are correct.
Old Feb 22, 2008 | 05:01 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Years ago pass side mirrors were an option or aftermarket on many cars. My Corvette does not and never did have one. It goes thru PA inspection like clockwork every year. Emmissions of course are not required.
