'98 4matic Wagon - How to access rear shock mount?
You can browse around here and maybe see some diagrams - some of the E320 and E430 diagrams are for estate/wagons:
http://www.detali.ru/cat/oem_mb0.asp?TP=1
http://www.benzworld.org/forums/w210...placement.html
ohlord seems to indicate that Mark Cummins is the guy to ask here on this forum.
http://www.performanceproducts4benz.....aspx?bmid=236
Pic for display purpose only
Autohausaz.com parts much less
Hydroneumatic shocks not air
check it is from the rear and not the front sway bar drop links.
ohlordnext mod
Ohlord, those WALD body kits really transform the look of the wagon without making it into a "rice racer". The V2 version is my personal favorite. For practical occasional use in the snow and everyday ride comfort, I would however opt not lower and stick with my 17" wheels setup(Dual spoke 17" on 245/45-17 from '04 W211 E500). Jonari is the exclusive distributor for WALD stateside and they are in Burlingame, just half an hour north of me. Real tempting!
pm mark see if he has more info.
HOWSER it looks good going by as well
awesome bodykit on that silver T model
WAW
amazing
looks bullish
great! especially that front (bumper) makes the nose look much more sleek, heavy yet sporty. less sluggish i would say... fantastic...
ok, if you didn't read it between the lines by now.... YES, i am jealous :p
happy posting
greetz from German autobahn land
cheers
Cool
Inspect the L/R suspension / sway bar end /have a friend bounce the car while checking for the noise
Also One can inspect the upper shock mounts with the rear panels removed
Drivers side remove the spare and then one can access the mount
Passenger side on mine the Bose Sub must be removed to access the mount
If You need step by step info use this
http://www.startekinfo.com/StarTek/
the problem was the mechanic did not tighted then rear shock enough..
I had the same symptom... bouncing on it had no problem.. only going over minor bumps...
problem went away after tightening the shocks
good luck
better get it fixed soon.Before it rips out.
