Central lock and passenger side mirror
Harbor freight tools.Remove each fuse to test.Fuse chart in the diy or tips section over on benzworld.org w210 section if you don't have the one the factory put in the side slot down with the battery.
ohlord
ohlord
So thanks again for all the help.
Strange that these goblins are hopping around in your fuse box
Might be time to try a hard reset of the system,will not hurt and might reset the unit.
ohlord
ohlordThe Best of Mercedes & AMG
http://w210.pietrzyk.net/disassembly_electrical.htm
step on the brakes for 30 seconds rehook up the lead,enter your radio code,start the engine turn the steering wheel all the way left to right and back again a few times,sync you windows and sunroof per the owners manual and see if that helped.
Anyway it works great. Thanks again ohlord
