20's on a 00-02 w210?
Old Apr 2, 2008 | 12:00 AM
516mbtek's Avatar
'06 CLS55 P030
Does anyone have or seen 20x8.5 or 9 (front) 20x10's (rear) on a 00-02 w210? If not how about a 19x10 rear? I have 18 x 9.5's in the back now and they are very close to rubbing the inside wheelwell with a 40 et. I am considering a 20x10 set-up and want to know if it is even possible....and if so what are the et's? I have a bent front rim now, need rear tires and am itching for new rims asap....Any input appreciated Thanks
Old Apr 2, 2008 | 12:34 PM
eXpLiCitW210's Avatar
I own a 1999 W210 Mercedes.
I dont believe a 20x10 wheel will fit. I was running 18x9.5 AMG Monoblocks in the rear with a 275/40/18 tire and when i took them off i noticed i rubbed a little bit. So i think a 20x10 will definately rub. I used to have 20x9 inch wheels and never had an issuewith rubbing, just ride quality kinda sucked .
Old Apr 2, 2008 | 04:11 PM
OldNate's Avatar
1998 E320
Please dont I'm preety sure they wont fit too. Keep the 18s...
Old Apr 3, 2008 | 08:31 PM
516mbtek's Avatar
'06 CLS55 P030
I am going to go with 19x9.5's and play it safe...
Old Apr 3, 2008 | 08:54 PM
ohlord's Avatar
19's
with 9.5's is far from playing it safe.First it will trash your ride,second it will crash the suspension,third when you drop it you will need to spend upwards of $600 in camber bolts and rear camber links to get it even close to being aligned.If not expect to go through some very pricey tires in a very short period of time.You have a 4matic and you can't stagger the rims and tire sizes so how do you think you are going to run a 9.5 up front?
even the E55 went with a 31 et on the front and had to roll the fenders with an
8inch rim and et35 with a 9 on the back
you don't stagger 4matics
Old Aug 26, 2011 | 09:26 PM
516mbtek's Avatar
'06 CLS55 P030
revisit
Old thread but just wanted to let everyone know I have been running staggered rims 19x8.5f et 35 and 19x9.5 r et32 for 4 or 5 years (80k miles) with NO PROBLEMS on my 4matic.
Old Aug 27, 2011 | 06:37 PM
Brau0318's Avatar
Mars Red 2005 C230k, 2001 E320 4matic
Thats great to know because I'm about to do it in my 4 matic and I think i'm going to buy 19's, I was wondering if it works on the 4matic. I'm moving to houston in a month too. If you know of any good shops in the area you could recommend that would be great.
Old Aug 27, 2011 | 07:44 PM
raymond g-'s Avatar
99 E320
but that's not the whole (critical) factors. focus should be on tire selection
for those rims which help determine suitability with your 4matic. as is, your
info doesn't help clarify whether the fitment is appropriate.
Old Aug 28, 2011 | 12:51 AM
mike430sport's Avatar
2000 E430 Sport
516mbtek I just want to see pics of you car. Sounds nice from the mod list.
I cant find any pics of it.......
Old Aug 29, 2011 | 12:48 AM
surakung's Avatar
W210
I am running 19X9.5 ET+20(rear) and 19X8 ET+20(front). No rubbing issues. No fender rolling. I don't see any issues here. I am looking to put 20X10 on the rears next.
Old Aug 29, 2011 | 12:50 AM
surakung's Avatar
W210
...oooops, you guys are talking about 4matics. My bad.
Old Aug 29, 2011 | 08:33 AM
Brau0318's Avatar
yeah but surakung thoose are the rims that I want to get. When you posted them on the pic thread, I feel in love.
Old Aug 31, 2011 | 03:10 AM
Ungarisch's Avatar
Tectitgrau S210
a while back I set the self leveling system to the lowest setting and believe it or not even at this height with the 18x10 et19 I had no rubbing issues at all, as you can see the sidewall is untouched after about 2 weeks worth of driving it at this height. Later I raised it back up about 1/2" to its current height. With the k-mac camber bushings and getting the toe to factory setting, my tires wears completely evenly.
and if anyone cares how the self leveling system works when adjusted manualy see my video below, the ride height settles a bit after the car drives off the ramp
<iframe width="480" height="390" src="http://www.youtube.com/embed/v48anheXnas?hd=1" frameborder="0" allowfullscreen></iframe>
Old Dec 29, 2015 | 08:01 AM
spaz5133's Avatar
2000 e320
Just put on 20 inch 100 spoke datons on my 2000 e320 4magic wagon so far not having any type of rubbing slight wobble at about 80 no worst then 100mph with the stock 16S any other issues I'll update my experience but so far pretty flashy ride for a wagon
