ENGINE OIL SENSOR - VISIT WORKSHOP
Can you update how do you solve this problem? Mine is having the same error rightnow? Will it solve by replacing the engine oil sensor?
Many thanks.
The oil level sensor is located in the lower half of the oil pan. Once the lower portion of the pan is removed, the sensor is easy to replace. IIRC, one bolt and a cable connection. The hard part is the pan. There is no molded gasket/seal from MB. You need to get the right sealant and make a bead along the edge of the pan and reinstall.
Thank you for your information. Based on your explanation, as long as the oil level is enough, my engine will works fine regardless low speed (80km/h) or top speed (240km/h). I replaced a new battery (DIN100), old one already dead, but the error persisted. Anyway, I will wait until the next oil change to replace the sensor if needed so.
Thank you so much.
Cheers,
I've been told my an independent shop that for the 1998/1999 models, this was a common problem and you had to replace the sensor in the pan. The shop also feels that has happened to mine. I'll have my replaced when I have the next oil change done. The warnings are annoying, but I since I know that the level is correct, no harm to the motor.
I believe this is what needs to be replaced, but haven't been by the shop to verify.
are there 2 different oil sensors ? I have a 2002 E320, I was getting the "ENGINE OIL SENSOR" Message for a while. Now I also get "ENGINE OIL LEVEL" Message.
Is it the same problem?
TKU Benz2002
The first thing to do is confirm the actual oil level mechanically (dipstick) since running the engine with a low oil level increases wear.
I have a similar problem with my 2001 E320, with less than 9k miles on it. Even though the oil level is exactly correct (and I've lowered it twice and then filled to the proper level) I get error messages (malfunction) all the time. Will tell me the oil level is low, then the next time out it will tell me it's high. One day I will drive it a few miles and no warning at all, then the following day will drive the same distance and get five or six.
Old thread but wanted to update my post for anyone that might have this problem / issue in the future. I recently had the sensor replaced and no more oil-level related messages of too high and then too low. Total cost was $450 for sensor and related oil & filter change.
