Spring/Shock Replacement
Old Apr 22, 2008 | 11:45 PM
h0rn3t920's Avatar
97 E420 W210, 95 Volvo 850 Turbo Wagon
Yo im replacing my shocks/springs soon and im deciding on 3 diff choices
1.Stock spring/Bilstein HD
2.Eibach Pro/Bilstein HD
3.Eibach Pro/Bilstein SP
My Current setup (stock springs and shocks) sags in the back slightly because i have a double subwoofer system in the trunk. and when 2 people sit in the back seat, the rear end sags A LOT. I want to get rid of that if possible. i know its impossible to get rid of all of it but i want to get rid of most cause its ridiculous now. I want a comfortable ride but a little sportier and a bit lowered. im Leaning toward 2 right now cause i think that would be most comfortable.
What You guys think?
Old Apr 23, 2008 | 08:17 AM
blueC230K's Avatar
2002 W210 M112 | 2021 X247 M270 | 2015 Audi SQ5 | 2015 VW Golf R
Hey man,
I think you should go with the last setup, Eibach/Bilstein SP. I am running Eibach Pro System (springs and shocks) with dot 2 pads all around. Drop is nice with 1-2 fingers gap. Corners flat on/off ramps. It's still quite comfy running on 18" in cities. IMO, my setup is not agressive enough. I think you can't go wrong with Bilstein SP though.
edit: I think once you change to sport springs/shocks, the car will not sag as much because the springs are stiffer...
Old Apr 23, 2008 | 11:52 PM
MG's Avatar
MG
Veteran: Army
1998 E430; 2007 Porsche 911 C4S Cabriolet; 2011 Expedition EL Limited; 2014 E350 Estate
I am riding Eibach Pro system now and love it. Huge improvement over the old setup.
Old Apr 24, 2008 | 12:05 PM
Ben'z's Avatar
E320
No.2, Eibach Pro/Bilstein HD is not a good combination.
The HD shocks are designed for regular lenth springs.
I personally like Eiback+Bilstein SP, the handle is better, and I don't feel the compromise of ride quality. But, the rear camber is the pain. Don't forget to consider it.
Just my opinion, hope it will help.
Old Apr 24, 2008 | 02:54 PM
raymond g-'s Avatar
99 E320
HD should be same length as OEM, though valved approx 10% firmer.
SP is valved same as HD but approx 1.5" shorter and designed to work with
lowering springs (i know that was a typo, Ben'z)
The length of travel is the same for both.
Old Apr 24, 2008 | 06:19 PM
Ben'z's Avatar
E320
You got me.
Error corrected.
Old Apr 27, 2008 | 05:18 PM
h0rn3t920's Avatar
wats with the rear camber?
Old Apr 28, 2008 | 02:50 AM
Ben'z's Avatar
E320
To correct the rear negative camber, you need the K-mac, camber arm from speedybenz, or track link from House of Power. Or... new tires.
