Oil plug leaking
Old Apr 26, 2008 | 07:07 PM
j944's Avatar
2002 CLK430
Oil plug leaking
I took my car to a quick lube for an oil change and now it is leaking from the oil drain plug. It is too late to call them since their closed.I jacked it up to tighten the plug up but its like the thing is striped. I cant tighten it. I also backed the plug out and it isnt cross threaded and goes in straight.
Did they screw this up or am I missing something?
Many thanks!!
John
Old Apr 26, 2008 | 07:40 PM
ohlord's Avatar
They did
not install a new crush washer.They did not use the proper procedure of suction out the dipstick tube.They did not install a fleece filter.They did not use mb spec synthetic 0w40 wt. oil.
That's what you are missing
Have them pay to fix the damage if they over torqued the plug and have the proper oil and filter and procedure done either by yourself or a qualified indie shop that knows what they are doing.
Quick lubes do not know how to properly change oil in a mercedes.
ohlord
http://www.mercedesshop.com/Wikka/OilFilter2
2.5 gallon oil extractor in everett at hb tools
filter at autohausaz.com fleece only
oil at napa 0w40 mobil 1 syn
Old Apr 26, 2008 | 08:18 PM
j944's Avatar
2002 CLK430
Thanks for the quick response Oh Lord,
I almost pm'd you when I wrote this.
I will take it in Moday first thing to chew them out before I go to MB.
Thanks again
Old Apr 26, 2008 | 08:48 PM
ohlord's Avatar
Don't
go to mb.There are plenty of good indies around if you don't want to diy.
PM me we'll talk.
Old Apr 27, 2008 | 11:43 PM
Richard / E320's Avatar
2001 E320
Many thanks!!
John
ohlord answered your question, but I can tell you that I recently did my own oil and filter change for the first time, and my E320 won't go back to the dealer for such an easy task. Mercedes makes it easy by having the filter mounted just under the hood; I wish all vehicles were like this.
I bought an oil extractor from Harbor-Freight and here's my link to the oil change process that I did...
http://www.geocities.com/mymercedesb...extractor.html
Old Apr 28, 2008 | 01:32 PM
j944's Avatar
2002 CLK430
That does look easy enough.It will probably pay for itself after a couple of changes.
Thanks again guys.
Old Apr 28, 2008 | 03:30 PM
ohlord's Avatar
The 2.5 gallon unit
is only 20 bucks,Richard just could not wait to get his hands dirty
So the 2.5 gallon unit pays for itself the first time out of the box.
ohlord
Old Apr 29, 2008 | 02:36 PM
Semikolon's Avatar
2001 E220T CDI Avantgarde, 2002 E55T AMG
do I have to use an extractor to change the oil? isn't it enough just draining?
Old Apr 29, 2008 | 03:49 PM
ohlord's Avatar
Much
simpler,neater,no worry of getting the car at the exact angle to drain it all out,all done from the top side,faster,the way the shop does it..............
ohlord
Old Apr 30, 2008 | 08:21 AM
01BlackE320's Avatar
01 E320
ahhh, but that wonderful feeling of sliding under the car on an old piece of cardboard to drain from the bottom. And of course getting your hands coated with smelly old waste oil. Who can give that up?
Old Apr 30, 2008 | 10:25 AM
ohlord's Avatar
That's
what I keep these for
ohlord
Old Apr 30, 2008 | 12:59 PM
01 E320
that is just beautiful
