Code P0335??
Old May 13, 2008 | 09:50 PM
hadam's Avatar
2007 S-550, 2001 E-430 & 1997 E-420
Angry Code P0335??
Today my 2001 E-430 did not want to start. I try again and car start to shake a little bit and CEL came on.
So I did not take it to work and left home.
This evening I started the car and it ran fine.
CEL was still on. So I used OBII scanner and read the code and it was P0335.
Any one know what is P0335 is for on W210??
Ohlord any suggestion?
Old May 13, 2008 | 11:02 PM
suicidal4life's Avatar
2001 E430
I think thats Crank position sensor but don't quote me on that.
Old May 13, 2008 | 11:44 PM
ohlord's Avatar
Yes
you can be quoted on that
unusual code though,check the wires going to the crank sensor.Make sure the clip is on and dry.Has it been raining and the sensor had water dripping on it?
If all looks good,clear the code and see if the condition repeats.If it does new cps is an easy install
autohausaz.com about 70 bucks and diy on benzword.org w210 diy section.
ohlord
Old May 13, 2008 | 11:46 PM
okc329's Avatar
1997 E320 (silver/black)
Info for my scanner ....
says crankshaft position sensor A circuit malfunction. I have no idea what "A circuit" means.
Old May 14, 2008 | 01:13 AM
hadam's Avatar
Yes it is Code P0335 for CPS
Ohlord and all other thanks, yes it is symptom of failing CPS.
Ohlord or some one can look the photo and confirm that I am looking at the right sensor.
Ohlord I removed the connector from CPS and check and all looks dry and tight. Althogh it started after we had again power car wash.
I think I will stop going to this touch less power car wash place. Every time I go I get some codes and CEL.
Any one know what size of Allen Ranch I will need to take sensor off. Is it matrics or english?
Old May 14, 2008 | 01:57 AM
husk323's Avatar
Tesla Roadster Sport
wasnt there a recall for this?
Old May 14, 2008 | 05:21 AM
ohlord's Avatar
Husk
that is a good question.Never heard of a recall on it they just get dirty or the magnet fails and it won't index the crank properly anymore.
Another good diy is over on mercedesshop.com
Talked a single mom and her 12 year old son through the diy last week so op should be able to handle it
bright flashlight and using the hood vertical release tab is the key to making it easier.
Old May 14, 2008 | 10:29 AM
ohlord's Avatar
Did
When you checked the fitting did you check for damage to the wires?
ohlord
Old May 15, 2008 | 01:41 AM
hadam's Avatar
What size of Allen Wranch I need??
Can any one tell me please what size of allen wranch? The is one Torx screw on CPS, any one know the size.
Old May 16, 2008 | 12:57 AM
gpl916's Avatar
E430 4matic
P0335
Hi,
I just got this code too. My car is sitting at Bartel's at the moment. I am trying to orient myself in the pix above- am I looking at the forward passenger side of the engine compartment from above?
Thanks,
Greg
Old May 16, 2008 | 01:15 AM
hadam's Avatar
It's on driver side. You are seeing master brake cylinder in first pic.
Old May 16, 2008 | 07:02 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
There goes Ohlord again, selfless helping others as he has helped me. Got nothing but good to say. Read and follow his advice. It will save you $$$$
Old May 16, 2008 | 07:13 PM
ohlord's Avatar
The
early two clip cps had the allen fitting on your 01 I think when you unhook the wire you will see a size 8 torx external fitting like all the ones on the front of the engine,so you will need a set of those from sears or maybe even the auto parts store.
Press the hood release tab up by the pass side windsheild so the hood tilts all the way up.Have a good flashlight and you look like you located it down on the bell housing and towards the back of the engine.It will take some twisting to get at it but you will
do you have the part yet?makes it easier to see how it all fits if you have the new part in hand.
ohlord
Old May 17, 2008 | 07:13 PM
hadam's Avatar
Thanks for reply - I got the Part from autohausaz.com AZ
Ohlard, thanks for your reply. Yes I did order the part and got it from autohausaz.com. I am out, I will work on it next week. I will let you know.
One question, why your profile is displaying "ON PROBATION", what in the world is going on here.
Old May 17, 2008 | 11:05 PM
ohlord's Avatar
I goofed
and offered a plug wrench for sale,and it was considered a TOU violation as a non commercial post.No big deal,can't read my mail for 60 days or something.
We had a great time this morning with Raymond,Jon,and John and myself doing the spark plug tutorial.Great to meet those members look at some cool mods and get a bunch of new plugs into some needy m112 engines.One had 130000 miles and the gaps were off by about .oo6 but they still had a good burn pattern and besides the heat which almost made me pass outwe had a blast.
Next I'm going to put on a polish and wax clinic to really make these cars show car shine.
Ohlord
