Need help wit zams bi-xenon
and i need to get them aligned more downward but it evidently has gone as far down as it can go.
the adjusting unit inside one of my lights is not sturdy. when i hit bumps it will wiggle. when i put in my lights one of the parking bulbs wouldnt go in so i pressed gently and the light made a clicking sound. i was nervous idk if i broke it or not but i doubt i broke it i wasnt pushing very hard. is there any fix for that?
and also, i have the OEM Xenon. It was a pain putting these lights in with the washers. I got the washers in, but i could NOT get them in properly. they are just sitting in there. is there any way to get them in perfectly?
someone who has the zam retros plz help i love these things and want to get them working 100% asap.
have a top fastener, and one below the low beam housing....and deep towards
the fender. those two are the primary fasteners for alignment. it may require
some pressure and rocking of the whole unit as you position it before tightening.
last, I tighten the one below the high beam housing which is a combo, large flat
washer with integral nut.
if you've pretty much tried that and still unable to get the headlight aligned, I'm
not sure what the problem is. I've not had any problems fitting Depo headlights
to 210 cars....and I've done about a half dozen of these. a small amount of
finesse is involved but nothing challenging about it. Don't know why your 420
would be different.
the inside linkage has been a weak spot with the aftermarket headlights, I opine.
not sure how to resolve unless I have it in my hand. fortunately, i've not hand
any problems with loose linkage so though I've been lucky here...it also means
that i'm at a disadvantage in trying to assist you here.
am trying to picture your description of the parking bulb. is this the city light....
the small 5-6 watt bulb above the high beam bulb? it should be a wedge bulb
W5W. you're saying that when you insert it into the headlight housing, it won't
go in? or, are you saying that you're attempting to fit the base/wire onto the
bulb?
your reference to OEM Xenon is painting a blank picture in my head. what is
the model of the OEM Xenon? from which car? is it a projector? and why,
after purchasing a Depo already retrofitted, are you having to money around
with washers?
take some pics or something. otherwise, your word selection is just generic
enough that I dont have a good idea what you're referring to .....especially
when we're trying to troubleshoot.
connection between the high beam bulb/circuitry and the city light bulb.
they should be operating under separate switching
If you pushed the leveling mechanism out of position you will most likely have to remove the headlight and see what's wrong... It may only be the little thing holding it in place in the middle between low and high beam.
The lights were not flush like OEM lights on my car .....just wanted to let you know that. The directions I sent you talk about how it can be adjusted to fit flush but I never did that as the black rubber from the depos always shows vs. the OEM lights.
If you really want to play around with that please PM Zam2000 and he can you give you some more ideas, raymond g has already chimed in else I would have recommended him as well.
Be careful when you are playing around I don't have Zam's original PM any more but he did mention that it is possible to move the xenon projector off-track if you tweak the wrong button.
Hope this helps......also the lamp defective has nothing to do with the Xenons as that never happened to me.
Cheers
