Comments on Ram Air
Old May 29, 2008 | 10:53 AM
Rostam's Avatar
97 420
Comments on Ram Air
The stock intake on the E420 is very restrictive. I was thinking about removing the cover and running a custom pipe from the MAF to the bottom right of the bumper.
I would bend the tubing coming from the bumper at a 90 degree angle to avoid water running into the engine and causing flood lock. I could also integrate a valved opening in the engine bay for rainy days.
I've seen many posts for hood scoop intakes, but I require some subtlety. What are your thoughts?
Old May 29, 2008 | 01:07 PM
lkchris's Avatar
'10 CL550, '12 GL550
You know this how?
It's an autobahn burner, driving like you'll never do in the USA and it does quite fine. Mercedes does NOT engineer strangled engines.
Old May 30, 2008 | 12:32 PM
atari's Avatar
1997 E320
yeah, I agree with lkc... air intake seems like a non-issue for the w210's, even for those rare e420's.
Old May 30, 2008 | 05:14 PM
Rostam's Avatar
97 420
The latches for my engine cover/intake have both broken. The intake just sits on the engine, so I must make a change soon.
Either ram air, or K&N filter sitting low.
Old May 30, 2008 | 06:25 PM
ohlord's Avatar
Fix
or replace the oem.Do not install K/N.
ohlord
Old May 30, 2008 | 07:05 PM
ron m.'s Avatar
1991 SC Miata, 1999 W210 Estate Wagon, 2014 W212 Sport Wagon
ohlord
What's wrong with K&N? Is it its ability to filter?
Old May 30, 2008 | 07:30 PM
ohlord's Avatar
oem
filter out flows even a day old k/n .oem filter is only 12 bucks at autohausaz.com
The m112 and m113 engines have no problems getting all the air they need through the stock air box and inlet at the grill opening.
ohlord
Old May 30, 2008 | 07:39 PM
thebenzbar's Avatar
MB
ohlord
Stock setup is about as good a ram-air effect you'll get... it's arguably even better than a GTO's Ram-Air setup! I know, I had a '70 GTO Ram Air III.
Old May 31, 2008 | 02:03 PM
Air Marshall Eldritch's Avatar
John Deere
Shut up Rob.
I have a pair of K&N for the W210 you can use.
