Idling Help!
Old Jun 4, 2008 | 05:50 AM
emanuelprz's Avatar
S-430
Idling Help!
Hey im new to mbworld,I just had a quick question for you. I have a 1996 E-320 it has 158K its been a good car unfortunatly I started to have a major problem i believe. When I put the car in Park or stop the motor will start to idle like crazy it will go from 0-2rpm non stop till i change gears in then it will continue to do it but not as much. This happends on and off. I would really appreciate it if you can help me out I would like to fix it my self if its not a major problem. please help me I dont want my car to screw up. Thank you.
Old Jun 4, 2008 | 08:08 PM
koskesh's Avatar
1997 E320
do you have check engine light on?
if not i'm guessing something to do with the idle controller valve.
Old Jun 5, 2008 | 05:54 AM
emanuelprz's Avatar
S-430
Idling help
the check engine light is on. I hooked up the ODB3 it reads "MAF or VAF A CKT range/perf" ( P0101) could it be that the maf sensor is just dirty?
Old Jun 5, 2008 | 11:48 AM
ohlord's Avatar
When they
get dirty or a bit out of range the codes are usually the fuel trim codes on both banks of cylinders.The p0101 circuit range code is most likely a bad maf circuit so firdt make sure it is plugged in and that the wires are in good shape if they are then a new maf (not ebay) from autohausaz,com will solve the problem.
ohlord
always a good idea to check all other systems at the same time,clear the code and see what codes return.Check all the spark plug connectors to be sure you have no misfires.
