I replaced my Seat Pad sensor, woot, no more SRS light.
Check the wires they are most often the cause and rarely the failure like the op.
If you have another car to drive do the diagnosis to discover if it is the wire and can be repaired and if not then order the part.Since most places have a no return policy on electrical items.
ohlord
woot to the op he really saved himself some loot doing the diy
removing the seat makes for more room to work and it is not that hard,besides you can really detail the floor when the seat is out and make it nice and clean.A clean car is a healthy car
2nd. Buy the replacement sensor BEFORE you tear into the seat. I got it all apart and visually inspected the wires and found no visible deterioration. Called the MB Parts department at 4:10 Saturday afternoon to find out they close at 4:00pm until monday. . . I'm in Lima Peru monday. . .If it works out you don't need the sensor, return it. But don't get caught in a bind like I did (yes, I put the seat back together and in the car knowing full well that I was going to have to do it all over again.
3rd. The plastic clips that hold the jute to the leather need not be broken. If you grab the base with a pair of pliers and twist 90 degrees, they come right out totally reusable.
That is all, thank you.
Why did you put the seat back in,if you are going to be in Peru?
enjoy the trip and finish the job when you get home.
ohlord
ohlord
It´s the wifes ride. . .so, I couldn´t exactly have her rolling all ghetto. . .
